Transmission & Drivetrain Gearboxes, Differentials, Clutches
Type R Transmission problem!!!! help
Old Sep 9, 2008 | 11:55 PM
In3g_Eg6's Avatar
Default Type R Transmission problem!!!! help
Need help on finding out whats wrong with my Type R trans. It doesn't want to go into reverse. It gets stuck when I try to put it in reverse. Its able to go to the right side above reverse but not down into reverse. Before this happen once in a while in would grind going into fifth gear. What could be the problem??? syncros, clutch???
Old Sep 10, 2008 | 12:42 PM
IN VTEC's Avatar
Default Re: Type R Transmission problem!!!! help (In3g_Eg6)
Replace the 5-R synchro set and 5th gear if necessary. Happens all the time. You're lucky it's the cheapest out of all the synchro sets.
Old Oct 2, 2008 | 12:40 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
yeah you need to replace synchro set like IN VTEC said.
the grinding on 5th you were experiencing develops burrs off the synchro mesh teeth on the inside of the sleeve from crashing/grinding onto the gear synchro mesh teeth. they are basically sharp 'claws' now at the end of the sleeve mesh and that scratches and [freak]s up the splines on the hub. enough shifting and those burrs will bind the sleeve and keep from sliding from one gear to another.
Old Oct 12, 2008 | 05:52 PM
kasimmmmm's Avatar
does the type R tranny take the same syncro's and forks as the USDM transmissions...
Old Oct 16, 2008 | 05:27 PM
get RIGHT's Avatar
Default Re: (kasimmmmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kasimmmmm &raquo;</TD></TR><TR><TD CLASS="quote">does the type R tranny take the same syncro's and forks as the USDM transmissions...</TD></TR></TABLE>
Assuming they are both Type R, yes.
phantomgreyhatch09
K Series
Jul 29, 2010 12:55 PM
jimmyrab
May 17, 2008 05:43 PM
treplatano
17
Apr 6, 2007 02:57 PM
01PHytyper
Jul 9, 2001 07:51 PM
