Brief Valvetrain questions...
Old Jul 25, 2002 | 07:03 AM
631 Teggy's Avatar
Default Brief Valvetrain questions...
LoL
Old Jul 25, 2002 | 07:44 AM
Spade's Avatar
Default Re: Brief Valvetrain questions... (631 Teggy)
http://www.crower.com
http://www.portflow.com
http://www.zex.com
Old Jul 25, 2002 | 10:39 AM
631 Teggy's Avatar
LoL
Old Jul 25, 2002 | 11:19 AM
Austin's Avatar
Send your head to Portflow and have them P&P your head...they can change out all of the items for you, and you'll have a pretty good increase in the midrange.
Austin
Old Jul 25, 2002 | 11:42 AM
Spade's Avatar
The whole point in getting the springs and retainers is for a new cam.
Your stock assembly is more than sufficient for the stock cam.
I thought you were planning on getting new cam(s) already.
Old Jul 26, 2002 | 12:57 AM
kinesistech's Avatar
Default Re: Brief Valvetrain questions... (Spade)
Your cams should be the first purchase. Get whatever springs go with the cams you get. If you get hype-r cams get hype-r springs. Toda cams, toda springs. See, its easy.
Old Jul 26, 2002 | 07:06 AM
Spade's Avatar
It's can start to damage things. Vavle adjustments are cake......I did my first one in an hour (took my time) now I can do them in about 20 minutes.
Now, follow my link below and see how easy it is.......how to/valve adjustment.
Old Jul 26, 2002 | 07:29 AM
88_SC_CRX_Si's Avatar
New User
How bad is it that I still drive my car if I can hear a slit jitter (only) when I pass like 2000 RPMS... It's faint but you can hear it... I don't feel a power loss... But I also wouldn't really know... I shift at 3k, just to avoid ******* my engine...
That sounds more like detination to me... Have you checked your timing, etc..., also what octane are you using...
Try using a screw driver, or short peice of hose. Put the flat end of the screw driver, or one end of the hose on the valve cover. The handle, or other end of the hose against your ear and listen. Move it around and listen for the clicking. You should hear which ones are making the most noise...
Old Jul 31, 2002 | 12:50 PM
631 Teggy's Avatar
Default Re: Brief Valvetrain questions... (88_SC_CRX_Si)
LoL
Old Jul 31, 2002 | 12:52 PM
Spade's Avatar
Exhaust wrap. http://www.summitracing.com
Old Aug 1, 2002 | 06:27 AM
Mover's Avatar
If you go to siffer valve springs (without changing the cam) your going to lose power IMO.
I changed the springs, retainers, to some aftermarket ones and put the stock cams back in (Long story...I won't get into it now).
I'm certain I've lost some power but I haven't verified it yet on a dyno.
Old Aug 1, 2002 | 11:58 AM
631 Teggy's Avatar
Default Re: Brief Valvetrain questions... (Mover)
LoL
Mr Tickle
May 24, 2009 07:56 PM
Black R
Jun 15, 2001 06:58 AM
