*****b-series parts, ek and eg parts*****
Old Sep 9, 2008 | 05:28 PM
jdmdohcek98's Avatar
Default *****b-series parts, ek and eg parts*****
please go here for pics http://www.orlandoforums.com/f...54967
if you dont like the price make me a offer but please dont lowball and dont waste my time calling me about parts and then not buy!!!!!
everything is located by DISNEY exit 58 on i-4 and MUST BE PICKED UP 4077221902 Jon
Engine parts
cometic ls/vtec headgasket 81mm .30 $70
jdm itr 4-1 2.5 header bracket brand new keeps header from flexing $20
b&m used fuel pressure gauge $20
accel 255 obd1 injectors $75
jdm gsr obd1 injectors $50
gsr exhaust manifold $50
gsr flywheel $50
b16 disc $20
98 gsr crank needs to be micropolised $50
gsr a/c bracket $30
integra/eg drivers side b-series mount $50
b-series rear main seal $20
4 gsr pistons $50
4 gsr pistons and rods 1 set has a cracked piston the other has a bad rod *make offer*
stock motor mounts in mint condition $20 each
clutch line off a ek $15
upper drivers side bracket for a ek $10
p2e 96-98 civic sohc non vtec ecu $30
secondary o2 sensor $30
eg vx sohc vtec manifold missing injectors $25
96-00 parts
rear hatch edge is dented $20
hatch rear wiper motor $10
rear hatch latch $5
lower bezel to relocate radio to the bottom $5
personal hub $60
passenger side manual door panel $20
99-00 red grill $10
steering column cover $10
rear hatch license plate bezel $20
hatch tail light harness $15
si tweeters $50
cup holder $5
92-95 parts
rear hatch cover $10
fuse diagram $5
ex/si front lower control arms great if your trying to put a sway bar on your none ex/si $30
misc. parts
window parts make offers
oil cap $5
passenger side window crank $20
Modified by jdmdohcek98 at 12:01 PM 9/24/2008
Old Sep 10, 2008 | 03:28 AM
CubanoRockr's Avatar
Default Re: *****b-series parts, ek and eg parts***** (jdmdohcek98)
are the b16 pistons pr3 or p30 and are they standard or oversized?
Old Sep 10, 2008 | 08:09 AM
Default Re: *****b-series parts, ek and eg parts***** (CubanoRockr)
std pr3's
Old Sep 10, 2008 | 09:15 PM
bump
Old Sep 11, 2008 | 08:58 PM
bump
Old Sep 12, 2008 | 09:40 PM
bump
Old Sep 15, 2008 | 06:37 PM
bump
Old Sep 18, 2008 | 05:43 PM
bump
Old Sep 21, 2008 | 07:06 AM
bump
Old Sep 23, 2008 | 07:20 AM
bump
Old Sep 24, 2008 | 08:02 AM
bump
Old Sep 25, 2008 | 05:41 PM
bump
b18AM
Sep 23, 2010 09:51 AM
allanonjj
Jul 10, 2009 09:40 AM
jdmdohcek98
May 18, 2009 08:14 PM
idriveabluecar
Dec 2, 2006 05:54 PM
jimmhatch
Apr 30, 2005 11:17 PM
