chipped P28
Old Sep 9, 2008 | 05:23 PM
Mingo's Avatar
Default chipped P28
Anyone using a chipped p28 for daily driving? Is it safe for the motor? Asked different people got different answers..I need some feedback. Thanks
Modified by Mingo at 8:43 PM 9/9/2008
Modified by Mingo at 8:45 PM 9/9/2008
Modified by Mingo at 8:46 PM 9/9/2008
Old Sep 9, 2008 | 05:53 PM
88aeFC3S's Avatar
Default Re: chipped P28 (Mingo)
im running a p28 chipped ecu on a b20b turbo at 10psi boost. daily driving.
Old Sep 9, 2008 | 07:44 PM
Mingo's Avatar
Default Re: chipped P28 (88aeFC3S)
thanks...need more feedback
Old Sep 9, 2008 | 09:46 PM
.Grimace's Avatar
footwork mastery
yes, if it's just a stock map or something it'll run like a stock ecu. if you have a tuned ecu like 88aefc3s it comes down to how good your tune is not the ecu.
Old Sep 10, 2008 | 09:49 AM
Mingo's Avatar
Default Re: chipped P28 (.Grimace)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace &raquo;</TD></TR><TR><TD CLASS="quote">yes, if it's just a stock map or something it'll run like a stock ecu. if you have a tuned ecu like 88aefc3s it comes down to how good your tune is not the ecu.</TD></TR></TABLE>
Thanks
Old Sep 10, 2008 | 10:19 AM
Relic1's Avatar
it all depends on what's in that chip.
It can be fine, it can be certain death.
Yes there really is that much difference.
Tuning will produce the best results, it's also the only way to make sure that what's on the chip matches your setup.
typical ebay chip - I wouldn't wish those on my worst enemies.
Old Sep 10, 2008 | 12:00 PM
Mingo's Avatar
Default Re: (Relic1)
Old Sep 10, 2008 | 12:12 PM
madracer's Avatar
Hi,
I'm running a chipped P-28 in my B16A2 with a T-3 Turbo, the ECU is tuned for the car and it works perfect, the car is set to run 8-PSI boost right now and i'm very happy.
good luck.....
Old Sep 10, 2008 | 12:19 PM
SkoundrelUSA's Avatar
cute little bastard
Don't even bother unless you plan on getting it tuned via Crome or ECTune soon. Just a waste of gas and risky
Old Sep 12, 2008 | 11:48 AM
madracer's Avatar
Default Re: chipped P28 (SkoundrelUSA)
I do not agree with you on this, If you look at alot of what people is using, you will see and learn that most are on Hondata or Chrome, I certainly do not have any problems and i have friends with Hondata locally and same type of turbo setup like mines and they prefer my car the way it is tune because i get better MPG etc.....so go figure.....
Now i'm saying Chrome is the best but its alot better than alot out there, if you want the best then go Stand Alone which is $1800.00 so there you go.....
Old Sep 12, 2008 | 12:07 PM
Mingo's Avatar
Default Re: chipped P28 (madracer)
thanks for the feedbacks guys
tubed-ef
May 2, 2007 11:35 AM
DraginTeg93
Mar 17, 2007 04:16 PM
cbmprelude
23
Jun 11, 2006 08:01 PM
speedymon
Sep 22, 2002 05:39 PM
