90 rex big brake upgrade question.
Old Sep 9, 2008 | 05:13 PM
remoer's Avatar
From: fountain inn, sc. where they still rock banjos on porches, usa
Default 90 rex big brake upgrade question.
hi i'm in the process of doing a big brake up grade on my 90 crx and i'm looking for a simple answer if possible. now i've readed brakefast write up and othe forums but i'm still looking of and answer.
here's my simple list:
1993 VW Corrabo rotor 11"
1993 Acura Integra caliper
Fastbrake brakets
now i've been reading here and there about the 1995 Acura Legend 2 pot calipers. now i've been told that swaping calipers from the integra to the legend will benifite me better. but i was also told that it wouldn't work with my spindle.
so can someone shine a lil light if it possible to use the legend cailpers instead of the integra. even if not possible what i would need to make it work
thank you
remo
Old Sep 9, 2008 | 08:08 PM
gunnerman's Avatar
Default Re: 90 rex big brake upgrade question. (remoer)
for 11" brakes you need DA brakes or 90-91 civic EX front hubs
Old Sep 10, 2008 | 04:23 AM
CRX Toad's Avatar
Read this one
https://honda-tech.com/zerothread/2103161
That is what you want.
Old Sep 10, 2008 | 07:22 AM
mike-y's Avatar
Default Re: 90 rex big brake upgrade question. (gunnerman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnerman &raquo;</TD></TR><TR><TD CLASS="quote">for 11" brakes you need DA brakes or 90-91 civic EX front hubs</TD></TR></TABLE>
fastbrakes sells a kit that works with the standard civic hubs and 9.5" brakes. its actually one of the cheapest kits he sells.
The legend calipers could be used, but you'd probably need a custom bracket to line them up right. Also, they may be setup to use a thicker rotor, so keep that in mind.
Old Sep 10, 2008 | 03:19 PM
remoer's Avatar
gunnerman - yes i understand that thats why i have DA calipers. but i'm asking to use the legends 2 pod calipers.
CRX Toad - yes i've readed that but jeez it seems alot of the answers are fuzzy, i'll read it again. at time i'm not the britest bulb in the pack. lol.
mike-y - you hit the nail on the head. "The legend calipers could be used, but you'd probably need a custom bracket to line them up right. Also, they may be setup to use a thicker rotor, so keep that in mind. "
thats what i'm trying to find out. if it's possible. i know i'm not only person on the net that has ask or done this.
FuNkDrSpOt
May 7, 2008 03:08 AM
remoer
15
Jul 17, 2007 06:08 PM
92integraVTECgsr
Dec 21, 2004 03:31 PM
pelotudo
Apr 12, 2003 12:17 PM
JDM_DOHC_SiR
Sep 3, 2001 03:08 AM
