99-00 Si front sway bar into 92-95 Si can it be done?
Ok So did try searching on here for "front sway bar" but only got 1 thread about install into EK DX!
So I was comparing diagrams only and was wondering if the front sway bar from a 99-00 Civic Si would mount onto a 92 Civic Si. I already have a 24mm ASR rear sway but want to get a larger than 21mm front sway bar that will be at least worth the price for the upgraded diameter. The 99-00 Civic Si's came with a nicely sized 26mm, which would only compliment the rear set-up.
Anyone ever done it, know either way if it will work???
Modified by 92CivicSiOEM at 5:53 PM 9/9/2008
