2003 accord v6 tcs and emergency brake light problem
My car drives fine and i heard it was a common problem with this year. My tcs and emergency brakelight on the dash stays on when i drive. why is this? and how can i fix this? anyone knows please help me! THANKS!
Chances are the brake fluid level switch inside the resevoir has stuck. I have replaced a few master cylinders for this, ( the resevoir is NOT sold seperately ). If you unplug the brake fluid level connector, see if the BRAKE light goes out. If it does, you have found the problem. I'm sure the TCS DTC is related to this.
kcb203
Mar 8, 2006 11:27 AM
