Air conditioning Help
Old Sep 9, 2008 | 01:34 PM
bret99ss's Avatar
Default Air conditioning Help
Just purchased a 91 hatch, and Im trying to get the AC to work. Few questions:
1. When pressing the "AC" button is that supplying a ground or power?
2. I checked the voltage at the compressor and it has no voltage. Is there any "how to" write ups on AC or any advice anyone can share?
Thanks alot
Old Sep 9, 2008 | 06:08 PM
zrickety's Avatar
Default Re: Air conditioning Help (bret99ss)
there is a pressure switch and a relay you need to check. if the pressure is low, the compressor will not run. if the relay is bad, same thing.
if you search the archives, you will probably find a ton of information
Old Oct 3, 2008 | 08:40 PM
liznadrian's Avatar
where can i find more info on this. my compressor wont turn on and i can find a "ton" of information as stated above.
Old Oct 4, 2008 | 08:13 AM
honda.lioness's Avatar
1. With the fan switch in positions 1-4, pressing the A/C button supplies ground.
2. For a wiring diagram, Autozone has free online repair manuals for your Civic. Go to "Chassis Electrical" and then "Wiring Diagrams." The a/c system is there. For a step-by-step troubleshooting sequence, try http://media.honda.co.uk/car/o...6.pdf or go to http://www.honda.co.uk/car/owner/workshop.html and try first the CRX manual and then maybe the 1990 Prelude manual.
Caveat: I have been troubleshooting my 93 Civic's A/C and, after reading reports here and doing some continuity testing, I think the climate control unit's circuit board has soldered joints prone to failure. In particular, beware of the A/C switch's joints failing. I have a writeup on this at http://honda.lioness.googlepag...oning.
akb427
Honda Civic (2001 - 2005)
Jun 28, 2013 08:51 AM
tddavis45
Nov 22, 2012 05:15 AM
hatchet_honda
Jun 19, 2010 01:09 AM
totsie7944
Jun 18, 2009 10:25 PM
dohcFTW
Apr 22, 2008 11:10 AM
