oil consumption and coolant
Old Sep 9, 2008 | 08:48 AM
98exowner's Avatar
Default oil consumption and coolant
I consume about a quart of oil every 400 miles and about have a quart of cooland if that. Did a compression test got around 170 across the board. Runs great but just the consumption issue. Had a bad oxegen sensor but fixed that. What can I do to find out what it is?
Old Sep 9, 2008 | 12:15 PM
Boots's Avatar
Default Re: oil consumption and coolant (98exowner)
do a leak down test to pinpoint your problem...just because the compression numbers are consistent dosent mean you don't have a problem, or you can redo the compression test, but add a little oil to the cylinders to see if that number changes
Fat Chick Magnet
Nov 22, 2006 09:52 PM
blackeg
Mar 28, 2005 06:10 AM
1337 Si
Jan 14, 2004 07:03 AM
crx1856
Oct 11, 2003 11:11 AM
osuPrelude
Nov 4, 2002 08:53 PM
