High NO ppm fail on emission test 91 accord
Old Sep 9, 2008 | 05:13 AM
mikeszutu's Avatar
Default High NO ppm fail on emission test 91 accord
Hey guys I just did my emission test and I failed on high NO ppm but, the CO and HC are low. What should I do? I already tried cleaning out the EGR valve and, in the process of getting the spark plugs changed. Possibly it's the O2 sensor?
Old Sep 9, 2008 | 05:33 AM
dtapia's Avatar
Default Re: High NO ppm fail on emission test 91 accord (mikeszutu)
does the egr hold and stall or almost when vacuum is applied ?
Old Sep 9, 2008 | 08:33 AM
mikeszutu's Avatar
Default Re: High NO ppm fail on emission test 91 accord (dtapia)
"does the egr hold and stall or almost when vacuum is applied ?" - I don't understand the vacuum part..
I know the vacuum hose that connects to the EGR..
Old Sep 9, 2008 | 04:57 PM
dtapia's Avatar
if you use a vacuum gauge and apply vacuum to it while it is running it should almost stall or completely stall if so then egr ports are not plugged up.on the otehr hand if it does not stall with the vacuum applied them time to drill out the plugs and do some cleaning. but first check that.
drop me a email and i will send you the test procedure.
89westendhatch
Dec 11, 2007 09:36 PM
EdDuck
Aug 8, 2007 08:29 AM
scoobyghost
Feb 18, 2006 03:29 PM
staticrex
Mar 24, 2005 10:53 AM
