b18b in 96 civic hatch
hey guys iam swapping a 94 b18b into a 96 civic hatch this weekend, is there any thing you guys can offer me in advice to make my job easier, any little difference with mounts shifter wiring, can i just use the ecu from the 94 integra, will it just plug in, i have all the mounts from the integra, all both axle, shiftlinkage, all that, what will need to use or change just need some guidance from guys that have done it before
-you will use all of you 96 civc mounts except, you need the rear transmission t bracket from the 99-00 civic si.
-use the integra axles
-you will use the civic wiring harness.
-you will need a distributor jumper harness, repin the plugs, or buy a obd2 ls distributor
-you cannot use the ecu unless you buy a obd1- obd2a jumper harness, or just buy a obd2a ls ecu.
-use integra shift linkage.
other then whats listed you're set
Modified by .Grimace at 9:02 PM 9/9/2008
