Replacing an alternator (D16Z6)
Old Sep 8, 2008 | 08:14 PM
xnvb's Avatar
Default Replacing an alternator (D16Z6)
Is this tough to do on these engines? About how much can I expect to pay for a decent alternator, and would it even be worth it to attempt to go pull one from a junk yard?
Old Sep 8, 2008 | 08:19 PM
turkeyslow's Avatar
A alternator job is a easy one, I purchased my alternator from honda, however I recommend a advance auto, pep boys, or napa, go somewhere that will warrenty a product. Do a yahoo search for those places youll get a online price. Don't go to the junk yard your probably just going to end up with a alternator that won't work or will need replacing shortly after. Good luck
Old Sep 8, 2008 | 08:21 PM
94EG8's Avatar
Seagull Management
Default Re: Replacing an alternator (xnvb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xnvb &raquo;</TD></TR><TR><TD CLASS="quote">Is this tough to do on these engines?</TD></TR></TABLE>
It can be, if the bottom bolt seizes they can be a royal pain in the ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xnvb &raquo;</TD></TR><TR><TD CLASS="quote">would it even be worth it to attempt to go pull one from a junk yard?</TD></TR></TABLE>
If its been sitting out in the yard and you have to pull it probably not, around here they only last about 3 weeks outside sitting without being turned over before they seize. Maybe if you live in a dry climate it might be ok. At least check it make sure it turns freely and has some sort of exchange policy if it doesn't work.
Old Sep 8, 2008 | 08:42 PM
gsxr1k05's Avatar
they are easy as pie to change, and its best to buy one with a lifetime warranty. that way when it craps out you can just exchange it
Old Oct 4, 2008 | 10:42 AM
95exvtech's Avatar
Default Re: (gsxr1k05)
make sure you take the front driver tire off your gonna need to do that
blackludebosh
Aug 10, 2008 03:40 PM
gonzalezjk
Classic Hondas
Jun 17, 2008 03:22 PM
RemoveGiantWingOnYourCar
Jun 30, 2006 05:25 AM
bigbearballs
Dec 1, 2004 06:47 AM
X-Static
Sep 9, 2004 10:46 PM
