is my clutch dead
Old Sep 8, 2008 | 07:02 PM
vinceg143's Avatar
Default is my clutch dead
clutch is sunk to the floor used to be able to pump it back up now i cant
Old Sep 8, 2008 | 07:30 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: is my clutch dead (vinceg143)
Did you try to bleed the clutch? Is there fluid?
Old Sep 8, 2008 | 07:32 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: is my clutch dead (PhantoM.DA)
EH, didn't pay attention to what you said, its probably the slave or master cylinder.
Old Sep 8, 2008 | 07:54 PM
vinceg143's Avatar
this sucks i can even drive it to go get fixed
Old Sep 9, 2008 | 03:55 AM
na+b18c_hatch's Avatar
yeah sounds more like a cylinder problem, not an actual clutch problem. check your fluid and around your clutch master cylinder to see if you might have a leak.
Old Sep 9, 2008 | 07:14 AM
EkFG's Avatar
Default Re: is my clutch dead (na+b18c_hatch)
yeah deff sounds like a master or slave cylinder problem, not the clutch.. check them over and bleed make sure the master is not leaking from under the dash.
WillyD
Transmission & Drivetrain
Oct 1, 2011 10:04 PM
zach1288
Jan 21, 2010 03:16 PM
crxricer66
Dec 1, 2007 07:58 PM
aengnr1
Jun 16, 2003 12:23 PM
SloCivicHMM
May 12, 2003 01:57 PM
