Popping sound under hard braking
Old Sep 8, 2008 | 05:14 PM
K20EF8's Avatar
Default Popping sound under hard braking
Under hard braking, there is a loud popping sound coming from the front passenger area. Does anyone have any ideas what it could be?
Old Sep 8, 2008 | 05:38 PM
johnnyonth3spot's Avatar
Default Re: Popping sound under hard braking (K20EF8)
Bump I have the same noise. Wierd thing is it started after I changed my Inner tie rod, outer tie rod, ball joints and anti sway bar bushings.
Old Sep 8, 2008 | 06:08 PM
vtecb18c's Avatar
Default Re: Popping sound under hard braking (johnnyonth3spot)
bad CV joint is what it sounds like....does it click or anything when you turn or even just driving straight?
Old Sep 8, 2008 | 06:58 PM
K20EF8's Avatar
Default Re: Popping sound under hard braking (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">bad CV joint is what it sounds like....does it click or anything when you turn or even just driving straight?
</TD></TR></TABLE>no it doesnt. The CV joints are brand new aftermarket DSS 2.9s. Brand new wheel bearings and lower ball joints
Old Sep 8, 2008 | 07:01 PM
vtecb18c's Avatar
hmmm.....possibly at bad motor mount?? thats really the only other thing i could think of
Old Sep 8, 2008 | 07:42 PM
tylergwesterhold's Avatar
I would say motor mount as well. I had the same noise and it ended up being my front motor mount.
Old Sep 9, 2008 | 04:15 AM
redzcstandardhatch's Avatar
something different
Default Re: Popping sound under hard braking (tylergwesterhold)
i've been trying to find that same noise in my car for 2 years...
i think it might be the steering rack....everything else is 100% tight, cant find problems with the rack ,but might be something with that.
Old Sep 9, 2008 | 04:16 AM
slywfbpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tylergwesterhold &raquo;</TD></TR><TR><TD CLASS="quote">I would say motor mount as well. I had the same noise and it ended up being my front motor mount. </TD></TR></TABLE>It was your front mount mount and not your tranny? Because I have changed my inner and outer tie rods and put in polyurethane mount inserts on my driver and tranny mount (I already had changed out the mount inserts for the front and rear) and I still have the pop sound on the passenger side when braking. It isn't LOUD, but noticeable.
Old Sep 9, 2008 | 04:17 AM
slywfbpsi's Avatar
Default Re: Popping sound under hard braking (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">i've been trying to find that same noise in my car for 2 years...
</TD></TR></TABLE>Yeah, my last bet would be the rack end bushing, will replace that on the next paycheck.
ftrms
Dec 8, 2009 03:36 PM
allshownogo
Mar 14, 2008 09:10 PM
Phelixthecat
Dec 17, 2004 09:58 PM
chrisw
Mar 26, 2004 08:07 AM
Matgallis
Feb 20, 2004 07:21 AM
