h23 into 94 del sol??
Old Sep 8, 2008 | 05:05 PM
hhsboy30's Avatar
Default h23 into 94 del sol??
i have a h23 engine with trans from a prelude.. i need to know if this will fit into my
94 del sol. if so what do i need to get for it to fit? tips or help please??
Old Sep 8, 2008 | 05:31 PM
vtecb18c's Avatar
Default Re: h23 into 94 del sol?? (hhsboy30)
yes its possible...itry searching using the H-T search function...make sure you hit the archive button because im sure it was covered awhile back....if you dont come up with anything let me know and ill get more involved to help you out....im sure other people will chime in also
Old Sep 8, 2008 | 05:35 PM
batallic's Avatar
get the custom mounts, also u need the ecu
Old Sep 8, 2008 | 05:48 PM
grandtheftlunchbox's Avatar
I've never done an H swap before, but I do know you'll need custom axles and engine mounts. You cannot run power steering unless you notch part of the frame (if i remember right) and don't even think about running A/C haha. It's quite a bit more cutting than swapping in something like a B series. However, I can imagine it would be worth it since you could drop into the 13's with just the swap.
Edit: even better- you could do an H2B setup and not have to worry about routing the shifter cables, and since you wont have to buy engine mounts you can just put that money towards the H2B kit.
Old Sep 8, 2008 | 05:49 PM
nix94delsol's Avatar
Default Re: h23 into 94 del sol?? (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">^^ yea and i also heard you have to smash the strut towers in quiet a bit...</TD></TR></TABLE>
research before any more senseless drivel comes from your keyboard
its the same swap as an H22a
https://honda-tech.com/zerothread?id=650329
that should be all you need
Old Sep 8, 2008 | 06:00 PM
Default Re: h23 into 94 del sol?? (nix94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol &raquo;</TD></TR><TR><TD CLASS="quote">
why?
.........holy crap, Guess i was wrong. what car is that radiator and condenser out of????
Old Sep 8, 2008 | 06:47 PM
widebodyeg's Avatar
doing an h swap is the easiest swap ive ever done,first u need to get the custom mount kit,u will also need the halfshaft from a 1993 accord 5 speed and axles from a 1993 acura integra 5 speed,and for the passenger side axle u have to change the inner part that goes into the tranny to the accord one,u need to make sure u have enough clearance on the driver side for the crank pulley,u can hit it in with a hammer a little bit,cut a hole in the firewall near the bottom to run the linkage through and cut a hole where the shifter goes big enough to allow the shifter to move around and then drill holes so u can mount the shifter plate into position,now after all that is done bring the swap in from underneath the car(its easier that way),jack it up into place but dont bolt it in yet,mark where the mount hole is positioned on the passenger side mount to the bracket on the car,you have to drill a hole for the new mount on the passenger side and then you have to cut a little part of the bracket to allow you to shift in all gears,once the swap is mounted up install the axles,then u will need to extend some wires and change the injector wires to the prelude ones,make sure u use a internal coil distributor,and u have to plug up all the vacumm line ports that are not being used,u can use a p75 ecu for that swap or the stock ecu from the prelude or take a stock p06 and get it chipped for an h23,or u could spend the money to buy an h2b kit then its as easy as doing a b series swap,ive done 2 h22 swaps and they both came out great,so i know what im talking about
Old Sep 8, 2008 | 06:49 PM
vtecb18c's Avatar
Default Re: h23 into 94 del sol?? (widebodyeg)
^^^there ya go...lol...someone from experience right there...good luck bro and keep us posted on your build
Old Sep 8, 2008 | 07:15 PM
twinksack's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by widebodyeg &raquo;</TD></TR><TR><TD CLASS="quote">doing an h swap is the easiest swap ive ever done,first u need to get the custom mount kit,u will also need the halfshaft from a 1993 accord 5 speed and axles from a 1993 acura integra 5 speed,and for the passenger side axle u have to change the inner part that goes into the tranny to the accord one,u need to make sure u have enough clearance on the driver side for the crank pulley,u can hit it in with a hammer a little bit,cut a hole in the firewall near the bottom to run the linkage through and cut a hole where the shifter goes big enough to allow the shifter to move around and then drill holes so u can mount the shifter plate into position,now after all that is done bring the swap in from underneath the car(its easier that way),jack it up into place but dont bolt it in yet,mark where the mount hole is positioned on the passenger side mount to the bracket on the car,you have to drill a hole for the new mount on the passenger side and then you have to cut a little part of the bracket to allow you to shift in all gears,once the swap is mounted up install the axles,then u will need to extend some wires and change the injector wires to the prelude ones,make sure u use a internal coil distributor,and u have to plug up all the vacumm line ports that are not being used,u can use a p75 ecu for that swap or the stock ecu from the prelude or take a stock p06 and get it chipped for an h23,or u could spend the money to buy an h2b kit then its as easy as doing a b series swap,ive done 2 h22 swaps and they both came out great,so i know what im talking about </TD></TR></TABLE>
it was easy because i did it for him haha j/k
Old Sep 8, 2008 | 07:17 PM
widebodyeg's Avatar
Default Re: h23 into 94 del sol?? (twinksack)
yeah we can pretty much do any swap,they are all easy
Old Sep 9, 2008 | 09:04 PM
solsi2000's Avatar
oh yeah what about an sr20 with NOS?
Old Sep 10, 2008 | 07:06 AM
widebodyeg's Avatar
Default Re: h23 into 94 del sol?? (solsi2000)
nope never done that,mostly honda swaps,probably could do that though,anythings possible
Modified by widebodyeg at 8:21 AM 9/10/2008
Old Sep 10, 2008 | 09:50 AM
shaggyeg6si's Avatar
I've done many swaps before, and the H was always my favorite. Be prepared to spend about 3 days to do the wiring. Make sure you wire in the IAB's. They are there for a reason, and make a huge difference.
Old Sep 10, 2008 | 12:20 PM
EKTourque's Avatar
Default Re: h23 into 94 del sol?? (shaggyeg6si)
Would it not be a better idea to swap in an H22 than an H23, since its more or less the same hasstle?
Old Sep 10, 2008 | 02:50 PM
Default Re: h23 into 94 del sol?? (EKTourque)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKTourque &raquo;</TD></TR><TR><TD CLASS="quote">Would it not be a better idea to swap in an H22 than an H23, since its more or less the same hasstle?</TD></TR></TABLE>
less, its almost the same exact swap, just no wiring in Vtec
unless he does a head swap
Old Sep 10, 2008 | 04:06 PM
widebodyeg's Avatar
he already has the h23 swap
Old Sep 12, 2008 | 03:27 PM
get an h22 head, swap it on, and wire in vtec. its relatively easy that way you can do the head gasket and timing belt while its off as preventive maintainance
H23_del_soul
Aug 5, 2010 08:25 AM
Chief Sol
Jul 11, 2006 08:53 AM
summerofsam44
May 18, 2005 03:15 PM
Sikdelsolsi
May 3, 2004 06:52 PM
