Emanage Injector Wiring *asap help*
Old Sep 8, 2008 | 04:52 PM
Maple50175's Avatar
Default Emanage Injector Wiring *asap help*
Not sure if this is right. I did have CELS of misfires.
Do you hook it up like injector one to Injector one from emanage like this
Injector 4- P/R
Injector 3- Y/R
Injector 2- O/R
Injector 1- BL/R
Or does it go by firing Order?
I cleared the codes and it seemed to go away. I'm going to take it for a spin and see what happens. I will let you know.
Please let me know asap I need to get this tunned after i figure this wiring out
Thanks for your time
ALSO:
I hooked it up to the emanage support tool and seems to be ok EXCEPT I know i have a problem...
and the throttle position sensor reads like 100% when I barely touch the gas. when im idle it jumps ALL around.. something is totally not right with this. How do I fix it?
Modified by Maple50175 at 10:15 AM 9/9/2008
Old Sep 15, 2008 | 10:44 PM
siregcivic's Avatar
Default Re: Emanage Injector Wiring *asap help* (Maple50175)
i just recently helped a friend hook up the e manage in a ep3, and onestly, i hate that piece of ****...
i hooked up the injectors teh way it said, injector 1 to injector 1 and so on 2 to 2 3 to 3 and 4 to 4...
i did the same thing with the individual coil packs, and the damn car starts and idles fine, but when connected to the laptop to get some tuning done, it pops up saying that it has coils 2 3 and 4 wired up backwards, so i went through and chainged it and it wouldnt even run, so i put it back the way it was and it runs fine.. but theres a cel...
i told the guy to sell the pos e manage and go k pro
scooterbuilteh2
Oct 25, 2009 05:46 PM
CHRIS29
Jun 9, 2009 04:43 PM
Black DC2
Feb 26, 2006 07:54 PM
