crx wont start??!?!?!?!?!?!?
Old Sep 8, 2008 | 04:19 PM
tomek5x's Avatar
Default crx wont start??!?!?!?!?!?!?
i have a 89 crx si with a obd1 b17a1, and i was messing with the wireing for the radiator fan and now the car wont start, it cranks and there is spark and fuel pump does work but fuel injectors dont spray, so i have no idea whats wrong, there is no fuse i think since originally the car used a resistor for the fuel injectors so does anyone have any ideas????????? any help would be greatly appreciated, thankss
Old Sep 8, 2008 | 09:32 PM
90sedan's Avatar
Default Re: crx wont start??!?!?!?!?!?!? (tomek5x)
Obviously you did something that is preventing the car from starting. Go over your work once again and figure out what you did wrong.
What exactly does "messing with the wiring for the radiator fan" mean?
Old Sep 9, 2008 | 07:32 AM
jdmlover07's Avatar
all gotta say is trace your work, maybe disconnected something that you shouldnt off have or cut into something you didnt need to
Old Sep 11, 2008 | 10:19 AM
tomek5x's Avatar
Default Re: crx wont start??!?!?!?!?!?!? (jdmlover07)
the fan wasnt working since it needed to be wired straight to the ecu, so i decided to wire it to a switch somewhere on the dash, and i haver no idea what can i have touced,,,, is there any fuses relays for the injectors?
ONE-CAM-EF
15
Dec 2, 2010 01:36 AM
skitzboy311
May 5, 2010 05:54 PM
DOHCtorJT
Jul 9, 2002 07:56 PM
1hottEG6
May 8, 2002 06:47 AM
1hottEG6
May 7, 2002 02:17 PM
