Transmission & Drivetrain Gearboxes, Differentials, Clutches
MFactory 4.92 FD
Old Sep 8, 2008 | 09:15 AM
96Spec Ek's Avatar
Default MFactory 4.92 FD
Just wondering what others real world experiences were with this product. I have already rebuilt my sir2 b16 tranny with a mfactory 4.92 fd, long 1st, gsr 5th, and gearspeed 3,4,5 carbon synchros. I would like to see how they are holding up in drag racing use. I have heard all the horror stories of other fd's breaking after only a couple runs.
Old Sep 8, 2008 | 04:01 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: MFactory 4.92 FD (96Spec Ek)
If you're pushing serious power, I would recommend going with the Pro Series.
The oil passages for the First Gear needle bearings have sharp leading edges, which hasn't been an issue as far as I have seen.
The splines for the 1-2 hub don't taper out like factory counter shaft, but hasn't been an issue yet.
Otherwise, good stuff.
If youre not making serious power, many other companies make FD's as well...PIC, SRR, T1R, etc
Old Sep 8, 2008 | 04:21 PM
Aquafina's Avatar
I doubt he is boosted. Big power guys with big slicks run a 4.7 most of the time. Should be perfectly fine on an NA setup. If you're making big NA torque, make sure you're preloading on launches. More so for the axles sake than the trans.
Old Sep 8, 2008 | 06:08 PM
Antilag's Avatar
Default Re: (Aquafina)
I run the 4.05 900 plus hp. Launching at 13-14 psi put of the hole, cutting 1.6 60's with 24.5's at about 5.5-6 psi in the slicks. over 40 passes with numerous 9's and low 10's for testing and its holding just fine!!
Old Sep 8, 2008 | 06:34 PM
Aquafina's Avatar
Note that is the PRO 4.05 FD.
Old Sep 8, 2008 | 08:48 PM
96Spec Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">If you're pushing serious power, I would recommend going with the Pro Series.
If youre not making serious power, many other companies make FD's as well...PIC, SRR, T1R, etc </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">I doubt he is boosted. Big power guys with big slicks run a 4.7 most of the time. Should be perfectly fine on an NA setup. If you're making big NA torque, make sure you're preloading on launches. More so for the axles sake than the trans. </TD></TR></TABLE>
Yeah I wont be making too much power with my n/a 1.9L so I guess I should be alright. Thanks for your help. If anyone has any more insight feel free to share.
Old Sep 8, 2008 | 08:50 PM
96Spec Ek's Avatar
Default Re: (Antilag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Antilag &raquo;</TD></TR><TR><TD CLASS="quote">I run the 4.05 900 plus hp. Launching at 13-14 psi put of the hole, cutting 1.6 60's with 24.5's at about 5.5-6 psi in the slicks. over 40 passes with numerous 9's and low 10's for testing and its holding just fine!! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Note that is the PRO 4.05 FD.</TD></TR></TABLE>
I would hope so.
Old Sep 8, 2008 | 09:39 PM
MFactory's Avatar
Danny Smith (turbotyper@SPEC) was putting around 750whp through our Street Series 4.05 for 2 full seasons before he switched to the PRO and it still looks brand new, so I think your 4.928 should hold up fine under NA power
blazzer
12
Dec 4, 2014 06:19 AM
CHRIS S
Feb 17, 2010 10:11 AM
JTCdudeman
Oct 22, 2007 02:57 PM
Aquafina
Acura TL, RL & ZDX
23
Aug 5, 2003 01:05 PM
DIRep972
Sep 6, 2002 10:30 AM
