Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
home made alignment rack
Old Sep 8, 2008 | 05:03 AM
josh green's Avatar
Default home made alignment rack
Does anyone have any pictures as to what they have done to align their car themselves? I am looking to learn to do it in my garage and I want it to be accurate, not just eyeballing it. My car is just a DD but is seeing some mountain/track time. Also looking to use it on a friends drag car.
I have heard of people using a rod for toe measurements, but I really have no clue how to dial in camber other than just eyeballing it and contact patch after driving. I searched and didnt find anything, so I figured I would post. I was surprised that it wasnt a sticky or tutorial.
Old Sep 8, 2008 | 05:10 AM
pcorad's Avatar
Default Re: home made alignment rack (josh green)
Archived Search
https://honda-tech.com/zerothread?id=267237
Old Sep 8, 2008 | 05:56 AM
josh green's Avatar
thanks man, wish the pics were still up on it.
Old Sep 8, 2008 | 06:57 AM
ThoseDarnKids's Avatar
Default Re: (josh green)
Here's a detailed DIY alignment with some pictures...
http://elantragtclub.tripod.com/elantra/id554.html
Old Sep 10, 2008 | 09:41 AM
vansprinkle's Avatar
Default Re: (ThoseDarnKids)
Nice find Bobby. I assume with all your extra garage space you will be setting something like this up now? I need to get a little setup at my place so I can start doing my own alignments.
I think that you can do without the conduit. Just tie the string to the jackstands directly. You can still check to make sure everything is square without them.
Old Sep 10, 2008 | 09:52 AM
Default Re: (vansprinkle)
You have to use the conduit, otherwise, you can't properly square it up.
The conduit isn't there to just hold the string, it's there because you have to make sure that the distance between the strings on the front conduit is the same as the distance between the strings on the conduit in the back.
If you don't use the conduit and you simply set the string to be the same distance from the hub at all four corners, you could be left with a trapezoid because of the varying front and rear track widths.
The only way to get away without using conduit is to make sure the distance between the jackstands is exactly the same. That's just another measurement you're responsible for and it makes it harder to do without conduit.
Modified by ThoseDarnKids at 1:03 PM 9/10/2008
Old Sep 11, 2008 | 08:27 AM
pcorad's Avatar
Are the front and rear track widths different on most Hondas?
I'm specifically interested in the Type R and the RSX S.
Old Sep 12, 2008 | 09:50 AM
Ausmith's Avatar
Default Re: (pcorad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcorad &raquo;</TD></TR><TR><TD CLASS="quote">Are the front and rear track widths different on most Hondas?
I'm specifically interested in the Type R and the RSX S.</TD></TR></TABLE>
I'm 90% sure there is on the Type R. I don't know about the RSX.
The pictures of my DIY alignment are posted on another site. I don't remember which one...
edsperformance
Feb 13, 2013 04:27 PM
Rob91DA
Northwest
Feb 15, 2011 06:15 AM
z168
Dec 17, 2004 04:04 PM
Shmeek
17
Mar 4, 2004 06:15 AM
