DOM=CHROME MOLY for NHRA cage specs???
i am getting ready to order DOM for my NHRA roll cage going in a crx and i need to know if i go off the wall thickness for chrome moly or if i go off the wall thickness of mild steel, since DOM is stronger...thanks in advance for any info
i know that...im asking that i am going to have a roll cage built in my car according to NHRA rule book specs and i need to know since they dont mention what wall thickness to use for DOM do i go off the rule book wall thickness for chrome moly tubing or mild steel?
if its mild steel it needs to be the mild steel spec f its moly then its the moly spec
dom has nothing to do with it. It is a manufactureing process and doesn't change the required wall thickness for the material used if your going to use dom sild steel the try to get .125 wall rather then .120. They get really **** about the wall thickness on mild steel and can/will fail anything thats less then .117.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KFMRC »</TD></TR><TR><TD CLASS="quote">if its mild steel it needs to be the mild steel spec f its moly then its the moly spec
dom has nothing to do with it. It is a manufactureing process and doesn't change the required wall thickness for the material used if your going to use dom sild steel the try to get .125 wall rather then .120. They get really **** about the wall thickness on mild steel and can/will fail anything thats less then .117.</TD></TR></TABLE>
thanks for the info...i seen somewhere on here they might ban mild steel in the future?? any truth in that?
Yes it is but will have an ET limit of 7.50 and is even heavier then the 120-125wall
dom. Don't even think of using anything less then 135 wall in ERW becasue the chance of a tube measuring thin and the bar failing is really good.
http://www.nhra.com/contacts/tech_faq.html
This page tells you all about the thickness requirements. 0.083 is the thickest you would need if using chrome moly
advanracing62
Sep 14, 2002 09:42 PM
