Build Up D15B7 or Swap
Old Sep 7, 2008 | 04:41 PM
Boomboy14's Avatar
Default Build Up D15B7 or Swap
I havent seen too many people with hot d15b7's, i am still debating on the swap, otherwise spend 2-3k on the b7 or swap in a b16 or other motor.
Old Sep 7, 2008 | 04:46 PM
turbojdmhatch's Avatar
Default Re: Build Up D15B7 or Swap (Boomboy14)
b16's suck no power until VTEC and u still arent going anywhere. my b7 has 200k+ on it running 10psi with a greddy kit 450cc injectors and running 14s. if your gonna swap it get a b18.
Old Sep 7, 2008 | 04:52 PM
Default Re: Build Up D15B7 or Swap (grandtheftlunchbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandtheftlunchbox &raquo;</TD></TR><TR><TD CLASS="quote">There's a reason you don't see many people with D15B7 builds done right. There's a very small market for them, and they have very low power levels to begin with. You'd be much better off with a b18 swap.</TD></TR></TABLE>
fixed.
get a greddy kit and smoke b16 swapped hatches like me. its true that theres not much for the b7 but with a tune they can be really reliable and quick. crower is the only company to make rods for a b7 though
Old Sep 7, 2008 | 04:54 PM
https://honda-tech.com/zerothread/1991183
Old Sep 7, 2008 | 04:56 PM
grandtheftlunchbox's Avatar
Default Re: Build Up D15B7 or Swap (turbojdmhatch)
****! accidentally deleted my post.
Honestly if I had 2-3K I'd much rather do a b16 swap. and by the way, with that much money you could probably get a GSR swap. I dunno, its all in preference. I'd be very wary of turboing a b7 though.
Old Sep 7, 2008 | 05:00 PM
Boomboy14's Avatar
i know what turbo jdm hatch is talkiing about, i drove a civic hatch with a b16 and didnt really like the delayed pull, b18 is a possibility, my b7 only has 90k original on it so it should last. im hoping to pull 11's in the future, just have to decide how to get there.
christianK's Avatar
swap....
whats to be worried about?
Old Sep 7, 2008 | 05:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbojdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/1991183</TD></TR></TABLE>
Good info, but he kinda points out things that are already obvious. but, regardless, he is correct.
Old Sep 7, 2008 | 05:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbojdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">whats to be worried about?</TD></TR></TABLE>
Pencil thin rods, small ports, weak headgasket (I work at a honda dealership, I see blown headgaskets in these all the time)... I mean if you build it up you'd have more reliability but if you want to do it right youll probably spend more than 2-3K.
Old Sep 7, 2008 | 05:10 PM
Boomboy14's Avatar
Default Re: Build Up D15B7 or Swap (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">i say just drive it. if it aint broke, dont fix it. for real. </TD></TR></TABLE>
yes but i would like to go faster(sounds pretty childish, i know)i have liked fast cars since i was a little kid, i got a ride in a built pantera when i was a kid, he got it up to 140ish and i fell in love with speed from there on...
Old Sep 7, 2008 | 05:12 PM
Boomboy14's Avatar
and how do i get the trial user text out from under my user name, im not a trial member any more.
Old Sep 7, 2008 | 05:25 PM
naRIPSTA's Avatar
I am my avatar
With your budget, I'd probably swap in a Z6 or Y8. Then maybe do a budget boost type of deal.
Heck, check the compression on your B7 and if they're all good, boost it lol. If it blows, swap in another. They're so damn cheap nowadays.
Old Sep 7, 2008 | 05:30 PM
nix94delsol's Avatar
Default Re: (naRIPSTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naRIPSTA &raquo;</TD></TR><TR><TD CLASS="quote">
Heck, check the compression on your B7 and if they're all good, boost it lol. If it blows, swap in another. They're so damn cheap nowadays.</TD></TR></TABLE>
or save yourself the hassle and spend 2500 on an H22a and have the same power, with no tuning, and no worrying about a turbo failing
Old Sep 7, 2008 | 05:31 PM
naRIPSTA's Avatar
I am my avatar
Ah yes, H series. H2B baby!
Old Sep 7, 2008 | 05:36 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandtheftlunchbox &raquo;</TD></TR><TR><TD CLASS="quote">Pencil thin rods, small ports, weak headgasket (I work at a honda dealership, I see blown headgaskets in these all the time)</TD></TR></TABLE>
I don't work at a honda dealership but I too can attest to both of these problems, i've seen D15B7s drive rods through the block, and i've seen more D15B7s then I can recall with blown head gaskets, at least 13 of them, maybe more, hell i've got 3 in a corner of my garage ready to be stripped for aluminum for that very reason.
Old Sep 7, 2008 | 05:37 PM
Pencil thin rods, small ports, weak headgasket (I work at a honda dealership, I see blown headgaskets in these all the time)... I mean if you build it up you'd have more reliability but if you want to do it right youll probably spend more than 2-3K.</TD></TR></TABLE>
thats why i got a 3layer metal HG and headstuds
Old Sep 7, 2008 | 05:39 PM
Default Re: Build Up D15B7 or Swap (94EG8)
IMO the b7 is the worst engine honda ever built...other than the b21...
i can say this because its currently my "powerplant"
OP: im in the same boat as you, ive driven boosted a6's and the only difference i can feel between getting out of a boosted A6 and into a H22a is the BOV and the turbo spool
Old Sep 7, 2008 | 05:42 PM
Default Re: Build Up D15B7 or Swap (nix94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol &raquo;</TD></TR><TR><TD CLASS="quote">IMO the b7 is the worst engine honda ever built...other than the b21...
OP: im in the same boat as you, ive driven boosted a6's and the only difference i can feel between getting out of a boosted A6 and into a H22a is the BOV and the turbo spool</TD></TR></TABLE>
i feel the same way about the b7 but i also feel the same can be said about b16's no power until boosted. neither of them react well to basic bolt ons
Old Sep 7, 2008 | 05:45 PM
Boomboy14's Avatar
an h22a would be nice...pretty cheap too, i could always turbo that afterwards...
but how the hell do i get this trial user ish gone...
Old Sep 7, 2008 | 05:48 PM
h22 is nice but what about the cable tranny? dont people have to drill out sections of their firewall or engine bay for that?
Old Sep 7, 2008 | 05:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbojdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">h22 is nice but what about the cable tranny? dont people have to drill out sections of their firewall or engine bay for that?</TD></TR></TABLE>
its hydro tranny, cable shift linkage. and you dont HAVE to cut a hole, you can snake them under the firewall
Old Sep 7, 2008 | 05:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boomboy14 &raquo;</TD></TR><TR><TD CLASS="quote">an h22a would be nice...pretty cheap too, i could always turbo that afterwards...
read up on the FRM before you plan to boost an H22
94EG8's Avatar
Seagull Management
You have to drill a hole in the floor to run the cables up through and you need to cut the shifter hole larger, i belive place racing used to offer a shifter box though so you didn't have to drill the first hole. Or you could go H2B and not have to do any of this.
Old Sep 7, 2008 | 06:00 PM
^ true but then it gets expensive
EDIT: F*ck yeah 500
