Cutting hood supports for B18c1
Old Sep 7, 2008 | 04:15 PM
krazyblurtzcrx's Avatar
Default Pic Request! Cutting hood supports for B18c1
All the old posts pictures dont work.
I have a gsr using a efb2 kit from hasport and im going to use the sheet of plastic with paint method to figure out where to cut the hood.
But I cant take any chances as the valve cover is candy painted and need to be sure that it wont hit while the engine moves while driving
Please post a picture of where you cut your hood and whether it rubs AT ALL now.
Thanks for any help!!
Old Sep 7, 2008 | 06:15 PM
SIred91's Avatar
Rainman
Default Re: Pic Request! Cutting hood supports for B18c1 (krazyblurtzcrx)
I use those mounts with my B16A and I have no problem whatsoever, and I drive it hard.....
Old Sep 7, 2008 | 07:03 PM
88Hatchy's Avatar
I won't clear even if you cut all the webbing out. Mine still rubs on the front right corner (next to the timing cover) with no webbing and washers.
PS: I have hasport mounts
Old Sep 8, 2008 | 07:06 AM
v.i.massive's Avatar
i have a b18c in my crx,mine rub as well i cut out the webbing and it still rub so i went and got me a edm hood (zc)
Old Sep 8, 2008 | 07:19 AM
grog's Avatar
Default Re: (v.i.massive)
with all the webbing cut on a stock usdm hood mine rubbed, so I got a metal zc hood and a SIR style CF hood which both clear, but with the ZC hood i had to cut a bit of webbing (it lines up with the fenders and bumper much better).
Old Sep 8, 2008 | 07:26 AM
IT GUY's Avatar
Default Re: Pic Request! Cutting hood supports for B18c1 (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">I use those mounts with my B16A and I have no problem whatsoever, and I drive it hard.....
shorter deck height on the block of the b16a makes yours clear
Old Sep 8, 2008 | 05:05 PM
Default Re: Pic Request! Cutting hood supports for B18c1 (IT GUY)
Bump, Help dont let me ruin this valve cover! !! !!! !!
Modified by krazyblurtzcrx at 7:24 PM 9/8/2008
Old Sep 8, 2008 | 05:12 PM
88Hatchy's Avatar
What answer are you looking for? You either need to get a different hood or shim it WAY up.
Old Sep 8, 2008 | 06:46 PM
Default Re: Pic Request! Cutting hood supports for B18c1 (88Hatchy)
still ust asking for the picture so I know where to start and end the cuts... Ill shim it up too anyways
Old Sep 8, 2008 | 07:01 PM
grog's Avatar
put some painters tape on the Valve cover if you are afraid of scratching it.
Old Sep 8, 2008 | 07:09 PM
Radim's Avatar
Hood space won't work with a B18?
Dark_Teg
20
Apr 16, 2009 10:59 AM
freedm
18
Jan 14, 2009 07:08 PM
tylojake
Dec 23, 2008 11:46 PM
fuccarlos
26
May 26, 2004 10:33 PM
*Boostwerks*
41
May 10, 2004 11:31 AM
