Odd problem
Old Sep 7, 2008 | 02:27 PM
jak3th3snak311's Avatar
Default Odd problem
Just bought a 97 civic ex, runs good but has an odd problem. While revving it, at around ~1800 or so RPMs, it sits there and revs up and down continuously, until you rev it higher or lower. Once your get past 1800 or below 1800 its fine, but around there it just revs high than low, high than low. Check engine light is on, im assuming it because of this. The guy told me the code came up as air idle control. What could the problem be? and what should i look for? Thanks
Modified by jak3th3snak311 at 5:32 PM 9/7/2008
Old Sep 7, 2008 | 04:14 PM
Default Re: Odd problem (jak3th3snak311)
Anyone?
Old Sep 7, 2008 | 04:22 PM
v8killaz's Avatar
run the code and fix the engine light first
could be iat or iac sensor i think or just an intake leak
someone has to know on here
Old Sep 8, 2008 | 06:53 AM
any other ideas?
jeff gonzalez
10
Jun 27, 2019 10:16 AM
red_h
Oct 27, 2010 08:08 AM
ffspiel
Engine Management and Tuning
Apr 6, 2009 09:06 AM
Freeman1017
Aug 26, 2008 06:38 AM
