Transmission & Drivetrain Gearboxes, Differentials, Clutches
OEM or aftermarket clutch for N/A use ?
Old Sep 7, 2008 | 12:29 PM
itr1244's Avatar
Default OEM or aftermarket clutch for N/A use ?
need some suggestions for clutch
thank you
Old Sep 7, 2008 | 04:17 PM
Aquafina's Avatar
None. Action Clutch. I've used Exedy, ACT, and Action. Action is by far the best. I'm a little biased though since I've been running it for over 3 years now. 1MD 6-puck unsprung.
Old Sep 7, 2008 | 06:46 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Aquafina)
Depends on the power you're making. There's a huge difference between a 150 whp NA car and a 250 whp NA car
Old Sep 7, 2008 | 07:02 PM
itr1244's Avatar
Default Re: (Evs-One)
i'm making 210 max n/a 4.9 FD and light fly w.
Old Sep 7, 2008 | 07:43 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (itr1244)
I'd go with a sprung 6 puck setup, especially if you do some track days...Ive had good luck with ACT, Centerforce, and Clutchmasters
Old Sep 10, 2008 | 10:07 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: OEM or aftermarket clutch for N/A use ? (itr1244)
I did NOT vote, and as far as what clutch, it would depend upon what you want for a build. For instance:
140-250whp use Stage2 w/ carbon kevlar, 500 mile break in and smooth as it can be. You'll get great life out of it unless of course you plan on launching at 5K. In which case I'd recommend Stage4 which is a six puck sprung hub clutch. It will be a little grabbier, but nice in traffic and will be able to take all the beating you'd like to throw at it.
My Stage3 is great for a daily driver that just cruises and plays on occasion. 500mile break in and is smooth with longer life than Stage2. Plate load remains the same, but you're good to 350whp all day.
Feel free to ask any more questions.
Chris H.
Old Sep 29, 2008 | 07:32 PM
goforbroke's Avatar
MEAT PATTY
Default Re: OEM or aftermarket clutch for N/A use ? (Richard Noggin)
I'm not sure if you sold on buying an aftermarket clutch, but b19coupe who has built numerous NA motors for his own car and runs a stock ITR clutch. He runs it in all of his setups and said it holds the power fine. He mentioned that they explode around 280whp NA, but your not in that terrority so it wouldn't be a problem. I wouldn't recommend it to but b19coupe is no noodle.
ishnathan
24
Jun 29, 2008 03:36 PM
silverskateEF9
10
Oct 14, 2007 06:36 PM
98GSRDC2
Jul 8, 2006 05:12 PM
JFG Kevin
Apr 27, 2004 01:49 AM
ahead
Nov 18, 2002 02:59 PM
