Transmission mounting threads on block stripped
Old Sep 7, 2008 | 11:31 AM
Masic's Avatar
Default Transmission mounting bolt threads on block stripped
Hey guys. I just got my b18b and I noticed that one of the holes where the transmission bolts to have the first 2-3 threads stripped. The bolt goes in fine but I am just sometimes a paranoid person especially because I just got this engine. I am just curious what you guys think about this. Should I just ignore it?
Thanks
Modified by Masic at 4:42 PM 9/7/2008
Old Sep 7, 2008 | 02:33 PM
racebum's Avatar
Default Re: Transmission mounting bolt threads on block stripped (Masic)
i would. the bolt will still grab & torque right? quit worrying so much, get laid, you need to relax
Old Sep 7, 2008 | 03:45 PM
Masic's Avatar
Default Re: Transmission mounting bolt threads on block stripped (idrivesideways)
Thanks. lol. The engine will be putting out 300WHP so i was a little worried. The bolt will still thread in and toque. If worst comes to worst i will helicoil it.
Old Sep 7, 2008 | 05:24 PM
racebum's Avatar
basically, if you are making 300whp you have many places that are far more likely to break. rod bolts, piston rings, synchros, axles etc. you should be fine. also if it gets totally screwed you can tap it to the next larger size.
Old Jul 31, 2011 | 02:26 PM
vtecfed's Avatar
Default Re: Transmission mounting threads on block stripped
I know this is a old *** post, but what would be the next size up you would tap in a standard thread from M14x1.25? I have two holes stripped on the trans itself. I'm rebuilding another one and just need this grinding piece of **** to not fall down outta the car..thank you in advance.
Old Jul 31, 2011 | 07:57 PM
IN VTEC's Avatar
I would helicoil it if you have to repair the threads. The threads are m12x1.25.
Old Aug 1, 2011 | 04:17 PM
Pinner13's Avatar
deff helicoil i just did this for my motor mount on the engine block. took my time and everything came out great
boostedefhatch
May 9, 2010 09:06 PM
webbs2jzgte
Jan 24, 2009 08:38 AM
Drizzo
Aug 23, 2006 07:17 AM
slowassciv33
Apr 19, 2006 12:51 PM
mountaindewguy
Jan 31, 2006 10:11 PM
