problem with corner lights
The right corner light stays on and in the interior has an anoying beep sound every 2 or 3 minutes. The other problem is that all the tail and stop lamps works fine, but in the dash it indicates a stop light failure, help please.
PD the car is Accord EX 1994.
I read a few months ago on other forum that was a ground problem, but i don't find the info again. It is rare and I know that all the problems the car has is in one place because they start at the same time and I verify the service manual and they share ground connections at some points. I'll try to reach those grounds on the weekend re-check them.
Some of the problem it has right now are
Defogger not working
Wiper when the washer is in use not working
right corner light stays on all the time
4 time beep under dash every 2 or 3 minutes
