Rear disc brakes - changing rear bearing/hub - which one?
1992 civic HB
Hi guys, i went for an alignment yesterday and the guy pointed out that my driver side rear bearing is busted (the wheel shakes back and forth a bit). i found a thread about how to change those things, thank goodness it's easy.
I just put in rear disc brakes on my car and i don't know which rear hub to use. the weird thing is different cars have different prices, which is dumb.
i tried:
1994 del sol vtec
1997 del sol vtec
1999 civic si
94 teg
my question is, are rear hubs different for civics with drums vs discs. Or if i have to get one with rear disc, which one should i get since they all different prices. thanks!
i tried:
1994 del sol vtec
1997 del sol vtec
1999 civic si
94 teg
i can do that, but i think the teg parts are more expensive, which doesn't make sense IF they are the same as the other parts, which is my question.
I'm just glad its an easy swap!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 »</TD></TR><TR><TD CLASS="quote">i can do that, but i think the teg parts are more expensive, which doesn't make sense IF they are the same as the other parts, which is my question.
I'm just glad its an easy swap!</TD></TR></TABLE>
I seem to recall integras using a larger rear spindle, which would mean a different wheel bearing, this info came from a questionable source but its all I have for info.
delsolo95
May 19, 2012 11:12 AM
beedoublejay
Oct 15, 2004 09:13 AM
beedoublejay
Oct 15, 2004 07:36 AM
