How to bake housing for JDM headlight?
hey,
im getting my JDM front end put on tomorrow....but i need to bake/paint my driver side headlight... im kind of nervous to do this, so can somebody PLEASE give me the steps to baking a JDM ITR one-piece headlight? thanks a lot!
First preheat the oven to 250 degrees. Grease your pan. Remove the headlight when a nice golden brown (after about 5-6 minutes).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">First preheat the oven to 250 degrees. Grease your pan. Remove the headlight when a nice golden brown (after about 5-6 minutes).
This also works great for fishsticks. MMMMMMMM fishsticks.
</TD></TR></TABLE>This also works great for fishsticks. MMMMMMMM fishsticks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">anyone have the recipe for baked JDM tailights?</TD></TR></TABLE>
I actually like my tail lights breaded with panko and deep fried.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Parada »</TD></TR><TR><TD CLASS="quote">a little o.t but
I smoke 2 joints before I smoke 2 joints, and then I smoke 2 more. </TD></TR></TABLE>
I prefer wake and bake method
OP..... i highly recommend you use a heat gun in place of a conventional oven to do this. Yes, it can be done, but you also haven't done it before and aren't familiar with the process.
A heat gun will allow you to concentrate the heat where it needs to be applied to soften the glue. Make sure you use caution when using a heat gun as well though. You can still melt parts of the headlight if you aren't careful.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">OP..... i highly recommend you use a heat gun in place of a conventional oven to do this. Yes, it can be done, but you also haven't done it before and aren't familiar with the process.
Good luck. </TD></TR></TABLE>
x2 i have also even used a hair dryer to pull apart headlights just be careful with whatever way you choose
thanks for the advice everybody...
i turned the oven up to about 375 degrees...put the headlight in for about 3 minutes. got most of the glue off, put it back in for 3 more minutes, and it worked perfectly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM*Teg »</TD></TR><TR><TD CLASS="quote">thanks for the advice everybody...
i turned the oven up to about 375 degrees...put the headlight in for about 3 minutes. got most of the glue off, put it back in for 3 more minutes, and it worked perfectly.</TD></TR></TABLE>
375 is a bit high and isnt really safe, with a lower temperature it takes a little bit more time but much less of a chance of melting things
also heat gun works but can be a bit more of a pain then the baking method
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote"> How to bake housing for JDM headlight?
-make your self small enough to fit in the headlight housing
-go in the headlight
-"hot box" the housing
hahahahahahahaha! I don't laugh out loud often but, damn, that one got to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL »</TD></TR><TR><TD CLASS="quote">
also heat gun works but can be a bit more of a pain then the baking method</TD></TR></TABLE>
true, 375 is a bit high. but it came out PERFECT. nothing melted whatsoever.
i did 375 for 3 minutes, took the headlight out, and got MOST of the glue off.
put it back in their for 3 minutes, and that was enough for me to get the rest of the glue off.
