Da dual core radiator in a crx with a/c?
Old Sep 6, 2008 | 07:37 PM
negum's Avatar
Default Da dual core radiator in a crx with a/c?
I'm not sure if this has been covered or not but will a DA dual core radiator fit in a crx with a/c?
Old Sep 7, 2008 | 08:55 AM
Crx Jimmy's Avatar
Default Re: Da dual core radiator in a crx with a/c? (negum)
yes
Old Sep 7, 2008 | 12:57 PM
blaak-crx's Avatar
Default Re: Da dual core radiator in a crx with a/c? (Crx Jimmy)
I had problems closing the hood and had other fitment issues It's abit taller then the stock Ef rad. For some reason, some Ef owners were able to fit it and some didn't fit. You may have to lean the rad and make new rad. brackets. Make sure that the lower hose doesn't rub to much against the cross-member too.
Read this for the installation:
http://www.performanceforum.co....html
Photos I found:
One of the problems I encountered:
Modified by blaak-crx at 2:06 PM 9/7/2008
Modified by blaak-crx at 2:09 PM 9/7/2008
Old Sep 7, 2008 | 03:41 PM
Crx Jimmy's Avatar
Default Re: Da dual core radiator in a crx with a/c? (blaak-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaak-crx &raquo;</TD></TR><TR><TD CLASS="quote">
Mine fit fine, even the stock fan bolted up. mine is like yours in this picture it barely clears but does fit under the sides, just spray some silicone on the locator pins/tabs on the bottom and push it in as far as it will go. There was no problem with the hood closing.
To the OP if you want I have a very nice DA rad I bought new and used for 2 years, I went to a different setup and needed a different radiator, it comes with a slim fan if you want it $50 plus shipping
alexEF
33
Apr 6, 2010 09:26 AM
EF9_RIDER37
Apr 3, 2010 08:57 PM
95_red_dc
Feb 6, 2009 10:31 AM
ham
Dec 27, 2005 11:50 AM
Magic Wheels
Aug 6, 2004 03:33 PM
