Need help on my setup.
Old Sep 6, 2008 | 06:45 PM
jim9's Avatar
Default Need help on my setup.
I was just curious if this setup will last me and what kind of power it will put out, If there are some parts that will make me lose power.. please let me know so i can change it or go some different route.. also also a newb on n/a. Thanks
B16a head
Blox Intake Manifold
Ported and polished
Milled
Custom GSR style combustion chambers for higher compression.
3 angle valve grind ( machine Work done by JG)
Supertech Dual Valve springs
Titanium retainers
A2 cams
B18a1 - Hottank/Bore/Honed/Micropolished Crank over Decked .007
PR3 Pistons 81.5mm w/ Hastings Rings on PR4 rods with ARP hardware
Brand new OEM Oil/Water Pump
ACL bearings
NEW OEM gasket and seals all around
ARP headstud
Ls/vtec kit.
going with 93 octane
Modified by jim9 at 7:19 AM 9/7/2008
Old Sep 7, 2008 | 08:45 AM
jim9's Avatar
Default Re: Need help on my setup. (jim9)
any advice?
Old Sep 7, 2008 | 08:47 AM
mariohonda(ed6)'s Avatar
that's a nice setup but i would not run the ACL bearing because they are known to wear fairly quickly from shop experience, i would run factory Honda bearings so it lasts alot longer
Old Sep 7, 2008 | 11:04 AM
DonF's Avatar
Default Re: Need help on my setup. (mariohonda(ed6))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mariohonda(ed6) &raquo;</TD></TR><TR><TD CLASS="quote">that's a nice setup but i would not run the ACL bearing because they are known to wear fairly quickly from shop experience, i would run factory Honda bearings so it lasts alot longer </TD></TR></TABLE> Must be a bad shop.
Old Sep 7, 2008 | 11:51 AM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mariohonda(ed6) &raquo;</TD></TR><TR><TD CLASS="quote">that's a nice setup but i would not run the ACL bearing because they are known to wear fairly quickly from shop experience </TD></TR></TABLE>
Can you elaborate on this because there are many users of ACLs on this board who have not had this experience.
Old Sep 7, 2008 | 12:19 PM
ruffrhyder's Avatar
I hope you have your flame suit ready
Old Sep 7, 2008 | 12:38 PM
jim9's Avatar
Default Re: Need help on my setup. (ruffrhyder)
anyways, back to topic... how does the setup sound? I'm trying to order a cometic head gasket, should i get the b18a1(which is my block) or b18a which stated as hybird for vtec head. Thanks
Old Sep 7, 2008 | 02:21 PM
PyroProblem's Avatar
A2 cams as in stock b16a2 cams?
Everything else looks pretty solid to me...
Old Sep 7, 2008 | 05:15 PM
DonF's Avatar
Default Re: Need help on my setup. (PyroProblem)
200 WHP depending on gasket. What did JG say about what gasket to use?
ryguy2588
Aug 29, 2012 12:58 PM
datflyboy
15
Dec 6, 2010 05:04 PM
madking411
12
Nov 17, 2009 08:54 AM
99SlammedCivic
57
Jul 1, 2008 04:48 PM
codyellis
Feb 28, 2008 02:02 AM
