HELP - Trouble all rear BRAKES LIGHTS out and AUTO TRANS will not go out of Park
Old Sep 6, 2008 | 12:15 PM
civichb20's Avatar
PM Garage
Default HELP - Trouble all rear BRAKES LIGHTS out and AUTO TRANS will not go out of Park
UPDATE : I found out after studying the wire diagram the horn was in the same circuit and the fuse was blown. My fault was I only bothered to check the dash fuses but not engine fuses assuming that it was brake fuse or something. Nothing like a good wire diagram to help you understand what is really going on.
THANKS FOR ALL THE HELP AND ALL THE HONDA LOVE THIS IS WHAT MAKES HONDA-TECH A GREAT PLACE I WILL MAKE SURE I WILL DO THE SAME
Modified by civichb20 at 9:52 PM 9/6/2008
Old Sep 6, 2008 | 12:42 PM
hometheaterman's Avatar
Default Re: HELP - Trouble all rear BRAKES LIGHTS out and AUTO TRANS will not go out of Park (civichb20)
Our 96 had this exact issue when the brake light switch went bad. You say you tested it but maybe check it again or try replacing it as when it goes that is exactly the symptoms it causes.
Old Sep 6, 2008 | 12:44 PM
frontwheelfanatic's Avatar
check the grounds for the tail lights in the trunk area
had the same problem in my old hatchback
Old Sep 6, 2008 | 12:47 PM
civichb20's Avatar
PM Garage
thanks for the replies
Does anyone know how the brake light switch and neutral safety switch are related
Thanks
Old Sep 6, 2008 | 04:08 PM
skilly's Avatar
Brake light switch registers when the brake pedal is depressed.
Neutral safety switch makes sure you are in park or neutral for the car to start.
Your car will not shift out of park without depressing the brake pedal, or from neutral to reverse or park without depressing the brake pedal.
Old Sep 6, 2008 | 07:17 PM
Pontas's Avatar
Could have a bad ground on the lights, but the tranny sounds like the linkage is clogged with dirt. I had the tranny thing happen on a 97 civic. The safety switch and lights may be related as far as wiring into the fuse box but Im thinkin its a bad ground or loose wire...
Old Sep 6, 2008 | 08:41 PM
Ross 2.0's Avatar
In a Junkyard near you.
It's the brake light switch. Very common issue.
Old Sep 6, 2008 | 08:51 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Ross 2.0)
I would start with brake switch. which you already did.
Check your stop/horn fuse. see if the horn beeps first- if not, the fuse is bad.
oh_dam
May 6, 2010 06:28 PM
erikwithak
10
Aug 9, 2009 02:39 PM
jbubsdc5
Apr 25, 2009 09:19 AM
keepitngga1
Jul 18, 2008 10:26 PM
yusoslo
Apr 20, 2004 10:08 AM
