chattering and no vtec!!!!
i was driving my 93 hatch (B16A), i have been getting a chattering noise lately.
i also noticed that when i try to hit vtec in 1st gear i doesn't switch over, but it will switch on the otyher gears.
i should mention this is not my DD, but i don't think that has anything to do with it.
Hmm that's weird, try replacing the VTec solenoid with one from a junkyard or borrow from a friend really quick? Chatting might be from clutch or trans.
EDIT: Maybe MAP sensor?
sorry for repling late, i noticed a couple of hours after posting that the vtec engaged. prior to this it was not engaging.
there are no CEL's. i did noticed it started after i replace the oil pan gasket.
now, i have no leaks, but the pan i have came off of a spare block that i have and it has a nice size dent on it. not sure if that plays a part.
yeah, that can cause your oil pressure to drop, or rise?? and that effects your vtec. iunno why its only happening in first, but switch it out with a dent free one and it should be working normal again.
My_EFsedan
13
Nov 3, 2012 04:21 AM
