teg vs si rear mount
Old Jul 24, 2002 | 09:37 PM
misledyouth's Avatar
New User
Default teg vs si rear mount
alright so i get my engine in my engine bay i get the two side mounts bolted up. And the back one is two long. the engine sits perftectly straight but then the back mount is about an inch to long. What i was thinking was it came out of a teg 92-93 xsi or whatever it's called cause the engine is stamped 91 and it's a pr3. but i don't know what to do is the 99-00 si mount a lot shorter?
thanks for your advice.
jesse
Old Jul 25, 2002 | 01:20 PM
00CIVICwB18C1's Avatar
Default Re: teg vs si rear mount (misledyouth)
The 99-00 civic SI rear mount is what you need
Old Jul 27, 2002 | 04:59 AM
Monty's Avatar
kind of oT ... but does that mean your putting a non obd motor in an obd2 car. Your sig says you have a 96??
Just wondering...
Monty
Old Jul 27, 2002 | 12:16 PM
IlikeTODA's Avatar
I'm confused. Your sig says H series engine, but the topic says teg? If you have a 6th gen civic and your dropping a B series you will need the SI mount like someone else also said. If your doing a H series I have no clue. I'm kinda prejudice when it comes to swaps. I guess I like B series cause thats the only thing I've worked on.
Thanks, J
Old Jul 27, 2002 | 01:11 PM
New User
Default Re: teg vs si rear mount (IlikeTODA)
i had an h22 in before but now i ahve a b16 in there it's in and running the sir mount is diffrent then the 99-00 mount i got that one and it works fine now. Everything is running good and strong. I got soem new brakes to teg front and rear and a teg 1 inch abs master cylender they are super nice for sure.
thanks for all the help
later
jesse
DSRxMilogen
Jul 25, 2004 04:19 PM
fowler!
20
Apr 27, 2003 05:30 PM
misledyouth
Jul 24, 2002 10:01 PM
