will the DA integra suspension work on an EF 1991 DX hatchback?
Old Sep 5, 2008 | 11:43 PM
949's Avatar
949
Default will the DA integra suspension work on an EF 1991 DX hatchback?
whole integra DA suspension to a 1991 ef hatch back DX.
i was curious if they will just swap right over?
if it does, is there going to be any issues?
i am looking to do it because i heard it does fit right over and also the DA will give it more of a stiffer ride.
Old Sep 6, 2008 | 12:15 AM
shinjitai's Avatar
Default Re: will the DA integra suspension work on an EF 1991 DX hatchback? (949)
https://honda-tech.com/zerothread?id=2377161
Old Sep 6, 2008 | 09:34 AM
949's Avatar
949
thanks. so i would have to verify with you. what they said for sure is that it fits but the DA length is longer then the ef. so it would bolt on but it wont lower that much compared to any ef setup?
Old Sep 6, 2008 | 09:50 AM
grog's Avatar
Default Re: (949)
it will raise your ef up since the springs are made for a car that weighs more. great for an offroad project
Old Sep 6, 2008 | 12:33 PM
949's Avatar
949
but from i read, i thought the main reason is because the shock body is longer.
now what happens if i got an aftermarket coilover made for the DA but i use i for the ef?
i wanted to get the stiffer DA setup versus the regular ef.
Old Sep 6, 2008 | 01:49 PM
sgallagher's Avatar
Default Re: (949)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 949 &raquo;</TD></TR><TR><TD CLASS="quote">but from i read, i thought the main reason is because the shock body is longer.
i wanted to get the stiffer DA setup versus the regular ef.</TD></TR></TABLE>
The stiffness is all dependent on the shock/spring combo that u use. The suspension other than that is not going to change.
If all you want is a stiffer ride you can get Ground Control coilovers in custom spring rates and match them to a good set of shocks like Koni yellows.
Besides the geometry is different on the front knuckles of the integra, they will still work just not as the suspension was designed to. If you want the larger brakes the best way to go is to use the Civic SiR front knuckles and then use the DA rear.
Old Sep 6, 2008 | 01:59 PM
grog's Avatar
Default Re: (949)
well there is a whole lot to choose from in the way of stiffer suspension for the EF, so no worries you can still get that teeth shattering ride with the aftermarket EF springs.
Modified by grog at 3:50 PM 9/6/2008
Old Sep 6, 2008 | 07:21 PM
949's Avatar
949
didnt know that ground control offers custom setting.
is that extra on the cost?
any good places offer them for a great deal?
Old Sep 11, 2008 | 10:26 AM
sgallagher's Avatar
Default Re: (949)
It is a little bit more but not much. Check out their website or some vendors here on h-t
Old Oct 17, 2008 | 12:27 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (sgallagher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgallagher &raquo;</TD></TR><TR><TD CLASS="quote">
Besides the geometry is different on the front knuckles of the integra, they will still work just not as the suspension was designed to. If you want the larger brakes the best way to go is to use the Civic SiR front knuckles and then use the DA rear. </TD></TR></TABLE>
What about Eibach Prokits from a DA on a 91 4 door???? The car I just bought is dropped 2.5" and I need it back to near stock height, but stiffer spring rates.
Maybe even H&R OE Sports from a DA on the 4 door?
The mud flaps scrape going down the highway!
lived dreams
Jul 9, 2009 12:19 PM
squeezedeghatch
Suspension & Brakes
Apr 7, 2009 07:34 PM
JDM91Bseries
Feb 28, 2007 09:09 AM
wangutang
Nov 10, 2005 07:10 AM
