UPS delivered these to me...
Going to go pick up my Legend GS 28mm rotors Friday.
it is width....
stock = 23mm
the Legend rotors I use = 23mm
other Legend rotors that can be purchased = 25/28mm ???
[corrected the stock size info]
[Modified by Willard, 7:49 AM 7/26/2002]
stock = 23mm
dont forget to mount the on the wrond sides
if you mount them with the left to right from the NSX , the bleeders will be on the bottom
just swap sides so the bleeders point up
is the Legend 28mm rotor from the 94-95 cpe with the two piston callys , just need to know for future reference
uh oh, ceramic coated? that might keep temps INSIDE the caliper instead of helping vent off temps.... you may wanna sandblast them before install, I dunno... just a suggestion.
Autozone rotors 0wn Brembo/Spoon/Endless/JDMgobrokealldatime
Jason-
who just picked up another set yesterday from AZ
[Modified by Jason Franza, 10:27 AM 7/25/2002]
Jason-
Are you sure the stock width is 25mm? Because the EuroDM is 23mm. It would be very very strange if the USDM one is thicker...
