No spark and no fuel
Old Sep 5, 2008 | 02:43 PM
Honda FTW's Avatar
Default No spark and no fuel
Hey all.
I'm new to this site and need some help with my 1992 honda accord wagon. I bought it for 200$ from a guy that had it sitting around for 2 years without moving. The biggest problem I am having is getting spark and the plugs. The owner told me he put a new coil cap rotor wires and plugs in it right before he let it sit, so 2 years ago. I checked all the parts and they are new and i have the receipt for them so they all check out. The first thing i noticed was the negative battery ground was completly green and half broken. After seeing this i checked the other grounds, and found the one that goes from the power steering pump bracet to the valve cover is very green as well. I bought those to items thinking i had a bad ground. I have not put them on yet. but i was wondering if there are other grounds i should check, the ecu grounds? If so where is it? Also I read a little on here and hear the main relay is a problem on these cars. If you think that could be the problem too, how do i test it? I also dont think im getting fuel into the engine, Im not sure but i dont smell anything, and for how many times i was cranking it i should have smelt something Any info you have for me would be great. Thank you all for reading this long post and for your replies
Old Sep 5, 2008 | 04:25 PM
dtapia's Avatar
Default Re: No spark and no fuel (Honda FTW)
crack the servie port on the fuel rail and see if the system is under pressure after cranking. if so then the main relay is working.
could have a failed igniter or coil.
remove the dist cap and see what color the igniter is black is the oki and is junk and the brown nec is the updated one.
check the coil they are fairly common along with the igniter
Old Sep 5, 2008 | 10:16 PM
jwicecold's Avatar
Maybe check all the spark plugs.. pull them out. If they are coated with **** they need to be changed out. Also for the fuel problem your injectors could be clogged from sitting for so long. or the fuel pump is garbage.. A few lil things for you to check.. ;-))
Old Sep 5, 2008 | 10:47 PM
Honda FTW's Avatar
thanks for the replys.... i pulled the plugs and they look fine after a little wire brush and regap. I will see if the system is under pressure after crank. but where is the service port i didnt see it when i looked the first time because i thought about checking that too. I pulled the ing coil wire that goes to the cap and put it next to a ground and it did not jump the spark. How do i test the coil, i have a dvom and know how to use it very well, i just dont know where to conect it and what readings i should look for. also im going to run some seafoum in the engine and clean the TB before i done with it. Thanks for the info more would be great! =]
Old Sep 6, 2008 | 09:01 AM
dtapia's Avatar
Default Re: (Honda FTW)
it should be on the fuel rail it has a 10mm cap on it.you will see the black fuel return line on the bottom if it.
Old Sep 6, 2008 | 03:36 PM
Honda FTW's Avatar
thanks for the info dtapia. do you know how to test the coil to make sure the insides are ok. so i can rule that out as my problem?
thanks
Old Sep 6, 2008 | 03:54 PM
dtapia's Avatar
yes i will email the info to you since posting stuff from ahm is no allowed
dinotapia@sbcglobal.net
Old Sep 7, 2008 | 07:29 PM
Honda FTW's Avatar
my email is puckett.brandon@gmail.com.... any other ideas on what it could be? anyone? im going to be working on it monday afternoon. Please any other ideas would be nice thanks to all
Old Sep 7, 2008 | 07:35 PM
Mr Yamada's Avatar
the ground wire at the T-stat housing is important for the ECU operation.
With the key on check for power on the Black/yellow stripe wire at the Dist plug; that will prove ignition switch okay.
Old Sep 7, 2008 | 07:43 PM
Honda FTW's Avatar
i will check that out Mr. Yamada... just to make sure the groud wire is right next to the tstat or where eles does it lead so i can check the other end as well. thanks
Old Sep 7, 2008 | 08:46 PM
dtapia's Avatar
honda ftw you have mail
Old Sep 12, 2008 | 04:01 PM
Honda FTW's Avatar
Well i tracked down the problem to the engine grounds, and the igniter. I fixed both those things and see fired right up like a brand new car. Thanks to all for the info and advice. Special thanks to dtapia for all this knowledge
JW2000CivicDX
14
Aug 4, 2014 04:30 AM
hey man
Jan 10, 2011 02:28 PM
jun10r27
Jan 1, 2010 08:53 AM
97honda civic dx
18
Apr 12, 2009 06:41 AM
junkyard racer
Jul 15, 2006 07:21 AM
