88 crx si stock cam
Old Jul 24, 2002 | 08:41 PM
B_1_8_hatch's Avatar
Default 88 crx si stock cam
if any of you guys have one laying around that you don't need anymore, i'll buy it off you for a cheap price. i'm not looking into
to spending a lot of money for this. if you have one let me know and let me know your price.
thanks,
93hb
Old Jul 24, 2002 | 08:49 PM
the DR.'s Avatar
Default Re: 88 crx si stock cam (93hb)
where do you live?
Old Jul 24, 2002 | 09:42 PM
CimorelliCRX's Avatar
Default Re: 88 crx si stock cam (CIVICtypeS)
i have a 91 si cam, it will work..
Old Jul 26, 2002 | 12:13 AM
Default Re: 88 crx si stock cam (CimorelliCRX)
i live in san marcos tx. how much would you sell me the stock 91 crx si cam for cimorelliCRX? how far are you from san marcos
tx? i'm 30 min away from austin and 45 min away from san antonio. let me know whats up.
thanks,
93hb
Old Jul 26, 2002 | 01:39 AM
91ED7Si's Avatar
the 89-91 cam is more agressive than the 88s anyways.
Old Jul 26, 2002 | 02:42 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: 88 crx si stock cam (91ED7Si)
define aggessive.
The cams have the same lift/duration/lobe seperation.
So how are the 89-91 cams more agressive?
Old Jul 28, 2002 | 03:58 PM
Default Re: 88 crx si stock cam (Mista Bone)
i did this mod,but really didn't feel a difference. what gap am i suppossed to set the lifters at? my car feels like it may want
to turn off sometimes. do i set the gap at the crx si lifters gap or at my dx gap?
Old Jul 29, 2002 | 02:25 AM
Mista Bone's Avatar
D Tranny Guru
well, there are NO lifters, and the specs for the valve clearances are the same.
What cam do you have and how is it timed?
Old Jul 29, 2002 | 02:53 AM
91ED7Si's Avatar
Arent the 88s 105hp and 98lb-ft and 89-91 are 108 and 100lb-ft?
And i thought the difference was the cam had higher lift.
Old Jul 29, 2002 | 02:56 AM
Mista Bone's Avatar
D Tranny Guru
nope.........
the difference is that 88 cams had the index keyway cut on the 1.5L setting.
The difference is in the keyway!
Old Jul 29, 2002 | 02:59 AM
91ED7Si's Avatar
cool
Old Jul 29, 2002 | 11:56 AM
i guess thats what i meant, the valve clearance. we didn't really know where to set the gap at. we set it at one gap, and you
could hear the valves tapping kinda loud. then we set it to another gap, and the valves don't tap loud anymore. the valve clearance is the same from the dx specs or the crx si specs? which one do i set it at?
i put an 88 crx si cam in my 93 dx hatchback. i don't really know what the cam timing is set at? how do you set the cam timing?
do i need an adjustable cam gear, would that help? a friend of mine will sell me his aem one for like $80. should i get it?
what do you suggest i do next? adjust the cam timing, if so, explain how the best way to do it is. i may feel a little difference, maybe i just expected to feel a little more. the only thing is, i think my car still feels the same, although i can chirp it in third now. let me know any suggestions that may help me out.
thanks,
93hb
Old Jul 29, 2002 | 10:20 PM
ttt
tgreaves
Nov 14, 2003 10:18 AM
BoostedD15B7
Apr 28, 2003 10:29 PM
B_1_8_hatch
29
Aug 7, 2002 04:50 AM
johnny hatchback
Jan 31, 2002 09:59 AM
