da Wont start
Old Sep 5, 2008 | 11:51 AM
mawibo's Avatar
Default da Wont start
So I'm driving up a hill the other day when my car decides to turn off. Now it wont start and when I try to start it occasionally I'll get popping from the exhuast. I replaced main relay. still nothing. Plugs have gas on all of them. I cant figure it out. Help please
Old Sep 5, 2008 | 11:54 AM
KILLAB17VTEC's Avatar
Genetically Gay
Default Re: da Wont start (mawibo)
pop in exhaust did u just recently got the motor washed?replace the injectors.
Old Sep 5, 2008 | 12:14 PM
IntegraMark's Avatar
check for spark. coil, igniter, dizzy...etc
Old Sep 5, 2008 | 12:17 PM
steveharrmr23's Avatar
Default Re: (IntegraMark)
it is the rotor in the distributor i know cause i had the same problem except on my dc2
Old Sep 5, 2008 | 12:22 PM
Default Re: (steveharrmr23)
so pull your cap off and look and see if you have a screw secureing the rotor to the shaft if that is not there then pull the rotor off if you look inside there should be a flat spot on the inside of it but if that flat spot is even slightly rounded then the rotor will shift forward and back effectivly advanceing and retarding the ignition causeing pops out threw the exhaust
Old Sep 7, 2008 | 12:16 PM
mawibo's Avatar
replaced the rotor and distributor cap. cars fixed! thank you all
Yama801
Jan 26, 2018 07:23 PM
ammob16
Dec 27, 2005 05:15 PM
Tee Jay
19
Nov 15, 2004 10:06 PM
jstlsn
Oct 14, 2004 12:59 PM
Spoonin
May 29, 2003 07:23 PM
