car wont start
hey so here is my problem. i did a simple head swap because my head was tapping. i had the extra head so its all good. dont tell me to do a valve adjustment
anyway, my problem is..
my car idles at 1400
i can pull my #2 spark plug wire and the rpms do not drop. every other wire made teh car drop and almost die.
and i hear this tapping noise.
i cranked the motor over with the valve cover off and all the valves move
i wont tell you to do a valve adjustment, i will ask you if you did.
did you?
ok so you are doing a ghetto power balance and #2 is dead.
did you check for compression in #2 or look if the plug is wet?
wait a minute your head was tapping?
did you?
car wont start/work right should have been the title...
i didnt do a comp check but it should be good.
i just looked and one of the injectors wiring looked a lil [freak]ed up cyl #2
does anyone have a diagram of a y7 dizzy and the correct firing order?
ill go check and see if the #2 injector is plugged in 100%
Modified by thebleek at 2:13 PM 9/5/2008
the engine is making noise so you throw a head at it. the cyl is dead, and you dont do a compression test.
plot thickens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote">
underseige2........assumptions are the mother of all f**kups.
plot thickens.
well check this.
i re wired my injector, now the cylinder works. now the tapping noise i heard is gone. now the only noise is the timing belt.....
im still idling around 1300-1500 it doesnt jump..its pretty consistant.
i got the firing order right, i think the tapping might be my timing belt, it looks way too loose and i cant get it any tighter!?
Modified by thebleek at 2:42 PM 9/5/2008
bump, car idles at 1500 and CEL keeps flashing.
but besides that it seems ok? its hard to start still have to give it gas but it will idle.
i think the gflashing cel is bad tho!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote"> now the tapping noise i heard is gone.
i think the tapping might be my timing belt, it looks way too loose and i cant get it any tighter!?</TD></TR></TABLE>
you're making no sense, is the tapping gone or not? also you said you're getting a cel. have you seen what cel that is yet?
the tapping noise that was under my valve cover is gone.
however...the timing belt is slapping i think and making a noise.
also, the cel just keeps flashing
well i adjusted my idle screw and now its around 1240 rpms.
but the CEL light flashes when my car is on!
but the only cels i get are for 71 and 72
misfire of cyl 1 and 2 WTF?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote">i think the tapping might be my timing belt, it looks way too loose and i cant get it any tighter!?</TD></TR></TABLE>
How loose exactly is loose? If its the right belt theres not reason you shoudn't be able to get tight enough.
now my fuel pump isnt priming. prolly a loose coneection or something.. i know its not the main relay.
i can hear it click. i just dont hear the prime. wtf.
and whats with the flashing cel?
poor_Type_caR
14
Apr 10, 2012 10:38 AM
big-cat
Jan 5, 2010 07:55 AM
s2kkk
Jun 15, 2004 09:25 PM
