Fuse popping headache..
Old Sep 5, 2008 | 08:49 AM
stratedrm's Avatar
Default Fuse popping headache..
my car: 95 coupe, turbo b20 setup, hondata s300.. tucked sohc vtec harness..
ok here's the problem..
car started popping fuse 31, which is the underhood ECU fuse. testlight/multimeter shows the left side of the fuse is seeing ground somewhere.. i began tracing the wire (yellow/white) that's shorting out..
i cant seem to figure out where the wire travels.. but i do know it goes to the pgmfi relay.. thanks to my trusty multimeter. i can seem to figure the wires path.. does it go under the dash to the relay? and could this be the only potential problem? the wire seems pretty healthy so far, no cracks or crimps, crushing or squeezing etc..
could it also be a relay? i can try a friends i suppose
Modified by stratedrm at 7:08 PM 9/5/2008
Old Sep 5, 2008 | 06:05 PM
stratedrm's Avatar
Default Re: Fuse popping headache.. (stratedrm)
Trvsteggy
Apr 21, 2018 02:54 PM
VegasEg8
Dec 20, 2013 08:27 AM
Blue94Accord
Dec 26, 2010 04:06 PM
frizzo
11
Jul 22, 2007 10:02 PM
