[95 CiviC Dx] Will A Hood Tilt Slow You Down or Cause Drag??
Old Sep 5, 2008 | 06:56 AM
Omega Blaze's Avatar
Default [95 CiviC Dx] Will A Hood Tilt Slow You Down or Cause Drag??
I heArd its like a vaccum. But i was still curious.
i seen it done with some cars at drag strips so,
i dont think it could mess with areo too much.
Any thoughts?? (Higher,Lower,etc)
Modified by Omega Blaze at 8:29 AM 9/5/2008
Old Sep 5, 2008 | 07:07 AM
john666's Avatar
Default Re: [95 CiviC Dx] Will A Hood Tilt Slow You Down or Cause Drag?? (Omega Blaze)
only time having a hood tilt is okay is when something under the hood touches.. besides that leave it alone
Old Sep 5, 2008 | 07:14 AM
suichgo's Avatar
not sure of the purpose, other than it looks nice sometimes
Old Sep 5, 2008 | 08:01 AM
z6hatchboy's Avatar
The "jdm" hood tilt lol, was orginally meant for cars with itb's because it does create a suction at the back of the hood and thats exactly what the itb's need. I cant say it would really slow you down, but i dont think you will be able to tell.
Old Sep 5, 2008 | 08:04 AM
Relic1's Avatar
the idea is that it helps with ITBs and underhood temps.
Not the best solution but it helps on some cars.
Old Sep 5, 2008 | 08:21 AM
Apotheosis's Avatar
lower lower lower... until its back to stock.
tilt ftl
not only will you not really feel any difference, the tilt just makes it look like your car was in some sort of front end collision and you didnt bother to get the hood fixed
Old Sep 5, 2008 | 08:25 AM
Archidictus's Avatar
Unceasing Measure
Default Re: [95 CiviC Dx] Will A Hood Tilt Slow You Down or Cause Drag?? (Apotheosis)
Technically, yes, inclining a large, flat piece of metal perpendicular to the airstream will add downforce. Will you notice? No. Does it look gayer than a pink fanny pack full of limp ****? Absolutely.
Old Sep 5, 2008 | 08:38 AM
naRIPSTA's Avatar
I am my avatar
Default Re: [95 CiviC Dx] Will A Hood Tilt Slow You Down or Cause Drag?? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Technically, yes, inclining a large, flat piece of metal perpendicular to the airstream will add downforce. Will you notice? No. Does it look gayer than a pink fanny pack full of limp ****? Absolutely.</TD></TR></TABLE>
AHAHAHAHA, truth!
Old Sep 5, 2008 | 09:00 AM
Agent_Samz's Avatar
Default Re: [95 CiviC Dx] Will A Hood Tilt Slow You Down or Cause Drag?? (naRIPSTA)
It's mostly for the show, not the go.
Old Sep 5, 2008 | 11:58 PM
mattv's Avatar
if you like the hod tilt so much put a h2b of k swap in there hahaha dosent look bad but i personaly wouldnt do it
Old Sep 6, 2008 | 01:11 AM
wildcat98's Avatar
its serves no good purpose ... but to raise under bonnet tempretures
Old Sep 6, 2008 | 10:17 AM
sageuvagony's Avatar
You're always trying something new eh? The power steering belt wasn't enough? lol nah I know you said you put it back. That tilt really does look like the car was in an accident and fixed incorrectly (like someone else said)
How people could think this looks nice in any way boggles my mind. Might as well do it to the doors and trunk lid then, or just drive with your hood, doors, and trunk open.
Old Sep 6, 2008 | 10:47 AM
S2L's Avatar
S2L
the area where the lower windscreen meets the hood is considered to be a high pressure area when the car is moving. when the hood is raised like that, air is forced into the engine compartment, not out. ITBs benefit from this because the air being forced in is cooler than the air thats been filtered through the radiator and AC core (if you had one).
Old Sep 6, 2008 | 10:51 AM
hgem1si's Avatar
Default Re: (S2L)
I've seen build threads where peoples motors don't fit properly, and it helps it to clear the hood.
The ITB thing is new to me, didn't know anything about that. All I know is regardless of there being a legit reason for it or not I think it's super duper gay.
Serdar
Jun 3, 2018 07:24 PM
4g4dcruisin
Sep 25, 2015 05:43 PM
97jdmdc2gsr
Mar 2, 2006 05:34 AM
InLimbo87
May 5, 2005 10:57 PM
ViperRedCRX
23
Jun 6, 2003 10:45 AM
