need help installin cvx cluster in civic
hey im havin da hardest time tryna install my crx cluster in to my hatch. wen i first got it i plugged it in and started it up the only thng that work was the speedometer. tach doesnt work high beam n check engine lights stays on fuel n temp guages move up n down wen i hit da high beam ***** funnie. i looked up some wire diagrams but mines doesnt match ne of them. help
well based on what your explaining i can tell you that the crx cluster is either a 90 or 91. The 88-89 crx's had the wires routed differently in comparison to the 90-91 years. THe cluster plugs i understand are the same, however the wires are in different spots. i believe in order to make this work properly you'll have to depin your current cluster plugs and repin them in the correct spots.
this should help
http://www.geocities.com/speed...r.htm
this should help
turboblack2door
Oct 29, 2012 04:20 PM
cjwarren4dcivic
May 25, 2006 12:09 PM
Gant
Jul 23, 2004 08:24 PM
