(DIY custom air box) cone filter VS. panel filter
Old Sep 5, 2008 | 04:39 AM
dpine's Avatar
Default (DIY custom air box) cone filter VS. panel filter
I am going to start my custom air box project this weekend and ran into a snag. While I was measuring the area I realized that its going to be a tight fit in the box with the BPI and the cone filter that comes with it. I thought about just using the BPI flow stack and then installing a panel filter to drop in virticallyon the other end of the air box.
So should I try to keep the cone filter in place of swap in the panel filter?
What would be the best senario?
Old Sep 9, 2008 | 04:57 AM
dpine's Avatar
Default Re: (DIY custom air box) cone filter VS. panel filter (dpine)
bump
Old Sep 9, 2008 | 07:21 AM
Relic1's Avatar
it depends on the design, engine behind it, desired power range from said engine, type of filter used, and a million other things that I can't think of.
as far as which would be better for you, there's no good way to tell from here.
My personal opinion, I've never been a supporter of panel filters. But I'm far from a fluid dynamics/air flow expert.
Old Sep 9, 2008 | 08:29 AM
dpine's Avatar
Default Re: (Relic1)
Thanks, basically a stock b18c5. The panel is only going to be used because of the cramped deminsions of the box, however I may beable to get a cone filter on by minipulating the space around the box (building a box that would fit like a puzzle peice).
conejo77
Honda CR-V & Element
Oct 12, 2014 12:28 PM
8OOSTED
105
Apr 23, 2012 08:30 PM
odiumred
Jun 22, 2007 11:27 AM
**DOHC HaTcH**
Feb 14, 2006 06:56 AM
nitrousrush
10
Mar 25, 2004 02:29 PM
