Cuts out at 3100 rpm in all gears even idle
Old Sep 4, 2008 | 09:41 PM
hhotek's Avatar
Default Cuts out at 3100 rpm in all gears even idle
we just dropped a 95 ls motor into a 94 ls car we ran into some problems because the car was originally an automatic and we did not know this so when we used the supplied 5 spd harness it had no fire at all. we swapped harnesses and its running now however it wont rev past 3100 or so it sounds like its banging off the rev limiter when we hit 3100
we have tried a second ecu and both are p75. we are throwing 1 trouble code its a 16 which says in the book that its a fuel injection code but i dont think that would cause the problem we are having. any help would be appreciated
Old Sep 4, 2008 | 10:28 PM
Steven.'s Avatar
Default Re: Cuts out at 3100 rpm in all gears even idle (hhotek)
their is an auto and a manual engine harness????
Old Sep 4, 2008 | 10:47 PM
hhotek's Avatar
yes there is the auto harness has 4 more plugs and the plug that plugs into the distributor is different somehow
Old Sep 4, 2008 | 11:38 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (hhotek)
Sounds like the car is in limp mode, when your throwing a code it does that.
Old Sep 5, 2008 | 12:02 AM
hhotek's Avatar
Default Re: (PhantoM.DA)
so fix the code and the problem should go away?
Old Sep 5, 2008 | 04:09 PM
BoSox46GSr's Avatar
usually fixing a problem will make it go away.
Old Sep 5, 2008 | 04:31 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hhotek &raquo;</TD></TR><TR><TD CLASS="quote">so fix the code and the problem should go away?
Correct
DMMF22B13
Oct 19, 2006 08:25 PM
DMMF22B13
Oct 16, 2006 09:08 PM
ay_dawg
Sep 20, 2006 01:56 PM
snowblind7x
May 25, 2006 09:19 PM
