Final Drive Install Help
I am posting here becuase its an ITR tranny and alot of you ITR guys have swapped in JDM or ATS final drive in to your cars, and some have done the work themselves. Well i got the JDM fd, thanks to ChrisJ
who had it for a great price, and ready to ship.
Anyways I have a few questions about putting the countershaft back together. Do I need to use the thrust shim that was at the bottom of the USDM countershaft on the new JDM one? It seems to big to use on the JDM countershaft.
I put it back together with out the shim and put the countershaft and mainshaft in the tranny. The gears didnt spin too easily. So I disassembled the whole countershaft. I guess i didnt press the gears on good enough. Everything seemed to line up good tho. The gears should spin easily, right?
I am gonna reassemble it tomorrow morning, should i use the shim?
Thanks
who had it for a great price, and ready to ship. Anyways I have a few questions about putting the countershaft back together. Do I need to use the thrust shim that was at the bottom of the USDM countershaft on the new JDM one? It seems to big to use on the JDM countershaft.
Thanks
Check to see that the force required to turn the input shaft with the case off is the same as with the case torqued down. If not something isn't right.
Thanks
I also have one more question. I am replacing the bearing in the picture below. Number 17. In the helms it shows a special gear puller to get it off. I dotn have that, so i was thinking of goin to the dealer to get it done, I have to go there to get some hondabond anyway. What do ya think they will charge and how long will it take.
You can get "hondabond" at your local autoparts store. It's called "Permatex Ultra Grey" liquid gasket maker...look on the back of the package and it should list the hondabond part number (which means it is a straight substitute for it).
It's half the price of what any dealer would charge.
The bearing had a small dent on it, and it was causing a loud clicking noise. I have no clue how it got dented. Maybee peices from when the old countershaft broke.
You dont always have to reshim it, just check its clearance. did the dealer charge you much to swap that bearing? I would have done it for a soda and a candy bar.
Maybe thats why I am so fat.
Michael Delaney
Jun 22, 2002 06:48 PM
gsr98vtec
Jan 2, 2002 07:42 PM
You seemed to sum it up pretty nicely.
