b16a obd0 cold start
I have a 88 crx si with a b16a. I have troubles with it wanting to start after sittin for awhile when it is less than 50degrees F. It will crank 10 to 15 times then start but when it does fially start it revs up and down untill it warms up. Also if you try to drive it before it is warm it will barely pull itself. All it has done to it is a intake and a cat-back plus i hollowed the cat. the things i've done to try and fix i consist of new plugs and wires, new o2 sensors, new map sensor, coolant temp sens, idle air control, and the sensor in the top of the intake manifold.
Also I've checked and all wires apear to be hooked up correctly
one other thing i had to hard wire the fan to a switch because it would not turn on by itsself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrod9989 »</TD></TR><TR><TD CLASS="quote">I one other thing i had to hard wire the fan to a switch because it would not turn on by itsself</TD></TR></TABLE>
that's actually pretty scary.
I'd go over that wiring again and make quadrupily sure the ECU is good.
CMunsterman
20
Feb 19, 2022 01:11 PM
djfob
Oct 23, 2009 01:59 AM
Hondzas
Oct 26, 2003 11:52 AM
