Coolant loss and eventual overheating 92 Accord EX
Old Sep 4, 2008 | 07:04 PM
kabhatti's Avatar
Default Coolant loss and eventual overheating 92 Accord EX
Hi everyone, I did do a search but still need to ask for fresh advice please. I have a 92 in which I have to add coolant every few days but do not have a visible leak. The car runs just fine at 228K miles. There is nothing unusual in the oil, nothings is smoking from the tailpipe, and not a drop of coolant anywhere in the system. I have replaced the thermostat, the water pump is new with the timing belt change. The passenger side fan does work, the driver side fan I have not seen operating after say 10 minutes of idle. I have bought a new radiator, just not convinced I should install it. Any new help please. I really like this car. Thanks for any advice.
Old Sep 5, 2008 | 02:53 AM
GhostAccord's Avatar
Default Re: Coolant loss and eventual overheating 92 Accord EX (kabhatti)
Have your cooling system pressure tested before you throw any more parts at this invisible problem. Once you add pressure to the system any leaks will show up that you may have.
Old Sep 5, 2008 | 03:42 AM
kabhatti's Avatar
Default Re: Coolant loss and eventual overheating 92 Accord EX (GhostAccord)
Thanks GhostAccord, I will try to have that done this weekend.....
Old Sep 5, 2008 | 02:14 PM
kabhatti's Avatar
Here's what I did to pressure test the radiator myself.... With an air compressor, I gently, put air into the recovery kit spill hose with the radiator cap on, I saw the radiator expand a bit, showing air pressure, the upper hose and lower hose were harder, (full of air), and then saw two visible leaks dripping from the radiator's bottom corners. I guess that settles it, I do have a leak. My only question is this, could I have caused the leak by putting air into it? I was very careful in not putting too much air into the system causing something else to pop. I see the radiator cap states 16 lbs of pressure.
Modified by kabhatti at 3:52 PM 9/5/2008
Skoalbandit
Jun 16, 2012 02:34 PM
RVD9431
Feb 18, 2011 09:30 PM
Integra4lyfe069
Nov 20, 2007 01:56 PM
Jedi_Sol
Jul 19, 2005 06:09 AM
92accord4life
Apr 18, 2002 09:07 AM
