Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
How does an 06 civic si coupe handle boost?
Old Sep 4, 2008 | 02:44 PM
91_civicsi's Avatar
Default How does an 06 civic si coupe handle boost?
well i had an old car, it rusted out lol, so now i have all these parts and no car, thinking of picking up an 06 si but im wondering how they handle boost? I have quite fair sized parts as i had a fully build lsvtec it was going onto , obviously i will have to get a custom manifold made because mine was for a b series
but could you guys maybe let me know what im expecting as for daily driver would handle it and stuff?
Old Sep 4, 2008 | 03:09 PM
ChargedSI's Avatar
Default Re: How does an 06 civic si coupe handle boost? (91_civicsi)
Can handles boost just fine as long as you can fuel tune it. Most are only running 4 to 5 psi, but that alone will get you to around 250hp to the wheels. Couple people have gone higher but until Hondata releases some type of programmable fuel tuning application, your options are limited. I run a Comptech Supercharger and love the ride. The car is built (currently) as a daily driver but it spends most of the time in the garage. If you start going over 9psi in boost, you might be putting the rods at risk. In addition, if you increase the redline much beyond the 8,200 stock redline, it would be wise to upgrade your springs and retainers.
There are a couple superchargers and Turbo's on the market. However, this is different motor and different car from your "old" car. Most of the parts you have sitting around will not work on this generation Civic SI.
Old Sep 4, 2008 | 03:26 PM
91_civicsi's Avatar
what wouldn't work? pretty much everything would but the manifold i would think? Turbo would be fine, ic, injectors, dp, bov, wastegate?
I dont see why they would not work, but thanks for your response
Old Sep 4, 2008 | 07:10 PM
vladd's Avatar
Default Re: (91_civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_civicsi &raquo;</TD></TR><TR><TD CLASS="quote">what wouldn't work? pretty much everything would but the manifold i would think? Turbo would be fine, ic, injectors, dp, bov, wastegate?
I dont see why they would not work, but thanks for your response </TD></TR></TABLE>
downpipe definitely wouldn't, since it'd be routed differently. you could probably use the flanges off of it, but that's it. dunno about intercooler, from what i remember seeing on the greddy kit, both the inlet and outlet are on the same side (unlike for b series, where the air goes in one side and comes out the opposite end). i'm guessing there's no room on the passenger side for the piping.
like ChargedSI said, the main issue with the 06+ civic is the lack of real fuel tuning. one way around that is to convert from drive-by-wire throttle to the standard cable throttle with parts (throttle body, ecu, pedals, etc) from the rsx, and run hondata on the ecu for tuning.
let us know how it goes . i want to turbo mine someday (in a few years haha).
azandford
Oct 25, 2009 07:24 AM
GSR_Hatch711
Feb 3, 2009 07:01 PM
07civicSI
14
Jul 31, 2008 09:53 AM
Nikoli
May 30, 2004 07:31 AM
flip1199
Jul 20, 2003 11:19 AM
