b16 vtec problems
Old Sep 4, 2008 | 01:44 PM
whiterex327's Avatar
Default b16 vtec problems
i have a 90 crx si with a b16a swap and the vtec wont crack. if anyone has had this problem or no whats wrong plz help
Old Sep 4, 2008 | 07:15 PM
zrickety's Avatar
Default Re: b16 vtec problems (whiterex327)
is it a new swap? has the vtec worked before? do you have a check engine light or codes flashing on the ecu?
Old Sep 4, 2008 | 08:53 PM
vtecb18c's Avatar
Default Re: b16 vtec problems (zrickety)
https://honda-tech.com/zerothread?id=164863
please use the search funtion next time
Old Sep 4, 2008 | 10:00 PM
SIred91's Avatar
Rainman
Default Re: b16 vtec problems (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiterex327 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 crx si with a b16a swap and the vtec wont crack. if anyone has had this problem or no whats wrong plz help</TD></TR></TABLE>
If your vtec is cracked, you have a serious problem.
Old Sep 4, 2008 | 10:09 PM
vtecb18c's Avatar
Default Re: b16 vtec problems (SIred91)
SIred whats up with all of these crackin their vtec...i know that the OP means vtec crossover but there has been a few thinking that by actually crackin their solenoids means their vtec will be louder lol
Old Sep 5, 2008 | 12:48 AM
G Type R's Avatar
try to check level of engine oil too.if low vtec not work
Old Sep 5, 2008 | 01:30 PM
its is a new swap but it came out of another crx so i just swaped everything over. the check engine light is on but it is only shows code 5 and thats the o2 sencer.
Old Sep 5, 2008 | 01:47 PM
zrickety's Avatar
pretty sure any check engine code will stop vtec from working. fix your codes first
Old Sep 5, 2008 | 01:57 PM
ok thanks
civicb0i
Jun 20, 2008 06:29 AM
b16edeg
Sep 21, 2007 11:48 AM
racereaper7
Sep 16, 2007 05:32 PM
Fastwhip
Aug 2, 2007 03:58 PM
mongoliandonuts
12
Mar 19, 2004 06:58 AM
