Will 95 Integra gsr oil pump work on a 2000 integra ls?
Old Sep 4, 2008 | 01:44 PM
95dc2teg's Avatar
Default Will 95 Integra gsr oil pump work on a 2000 integra ls?
just what the topic states. will it go in without a problem?
Old Sep 4, 2008 | 01:56 PM
kronikSLOW's Avatar
Default Re: Will 95 Integra gsr oil pump work on a 2000 integra ls? (95dc2teg)
i believe thats not your issue the flow is the issue not the bolt up i do belive.
Old Sep 4, 2008 | 02:38 PM
95dc2teg's Avatar
Default Re: Will 95 Integra gsr oil pump work on a 2000 integra ls? (kronikSLOW)
i realize the pressure will be a little higher, because the difference of a washer, but is this the only difference?
Old Sep 4, 2008 | 03:18 PM
egsleepercivic's Avatar
not 100% but I believe the obd 2 pumps have a sensor that the obd 1 pumps don't have, not sure though
Old Sep 4, 2008 | 05:15 PM
95dc2teg's Avatar
Default Re: (egsleepercivic)
^ this is true. but im sure the sensor could be swapped?
Old Sep 4, 2008 | 06:43 PM
Default Re: (95dc2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">^ this is true. but im sure the sensor could be swapped? </TD></TR></TABLE>
not sure if the obd 1 pumps have a spot for it, also the lower timing belt cover is different between the 2 to accomadate the sensor, the covers can be swapped, if you run the LS obd1 it should work fine without the sensor.
Old Sep 4, 2008 | 07:06 PM
95dc2teg's Avatar
yes the ls is coverted to obd1. i just realized that i have a extra 96+ oil pump from an old gsr that i should work, bc ive heard 96+ oil pumps are all the same through out the trims.
Old Sep 4, 2008 | 07:31 PM
Rickdrizzle's Avatar
I'd also like to know if a 96+ oil pump will bolt onto a 94-95 gsr without any problems?
sorry for the thread jack.
breakinpop822
Jun 2, 2007 03:12 PM
92integraVTECgsr
Jan 22, 2007 12:36 PM
mymeatb18"
18
May 11, 2006 06:17 PM
Mugencrxsir1
Apr 25, 2006 03:02 PM
MassScene
Dec 14, 2004 04:55 AM
